420 pto will not stay engaged
ky-green
03-28-2005 19:16:42
cannot even hold it in by hand with no load attached. any ideas? thanks
Henry J
03-30-2005 04:53:12
 Re: 420 pto will not stay engaged in reply to ky-green, 03-28-2005 19:16:42
KY
After you go thru that stuff Wayne referred to, I would try the following. However, I can't remember just how much yuou can see in there with the top of the trans pulled.
I would suspect something wrong with the travel the coupler (the thing that slides on the power shaft and engages the pto) is making due to worn or bunged up linkage such as the fork coming loose on the engagement shaft or the shaft bent or ?.
Once the engagement lugs get worn badly inside the coupler it bounces out of gear.
have you tried engaging it and then starting the tractor?
let us know what kind of trans and clutch you are dealing with. 4/5 speed live pto?
ky-green
03-30-2005 16:05:00
 Re: 420 pto will not stay engaged in reply to Henry J, 03-30-2005 04:53:12
thanks for the response guys! i haven"t had a chance to look at it yet, but it is a 5 speed with live power.
Wayne in Tn.
03-29-2005 03:59:01
Ky. Green, here are a few possibilitys. First check the roll pin that goes through the engagement lever, make sure the lever is not twisting on the rod. If that is ok then you may have some broken or worn parts. Under the left footrest there is a big nut, carefully remove it and watch for a small spring and detent ball. If they are ok, then remove the top cover and look for broken parts in the shifting detent and mechanism. At worse you could have a stripped cluster gear. Look for missing teeth and metal in the bottom of the transmission.
