HELP with a 45 Slant Dash A
brownjp
03-28-2005 17:49:07
I have just recently aquired a 1945 Slant Dash A and am in need of some help clearing up some things. Fist off any pictures anyone has of a 1945 A Slant Dash would be very help full. Just pictures of the dash and of the rear end and the hitch. My tractor came with one tank and a hood with only one hole for the gas but the dash has the rod for the all fuel were all 1945 A's all fuel. Other wise if not how would i shut off the gas or cut out the mag to shut off the tractor. The hitch in the back has also been modified a little so a picture would really help out. Any other information you could tell me about 1945 A's would also be helpfull. How many Slant Dash A's were made or what years did they make them.
1945 A
03-29-2005 06:07:14
 Re: HELP with a 45 Slant Dash A in reply to brownjp, 03-28-2005 17:49:07
Congratulations on your acquisition! I hope you enjoy using yours as much as I enjoy mine.
Like the other poster said, the only way to shut the engine off (and the one recommended in my JD owner's manual) is to shut the gas off and let it die. Don't use the choke, as that will draw extra gas into the cylinders, wash the oil film off the cylinder walls, and make the next start that much harder.
If you'll uncover your email, I'll send a couple of pictures of mine, though I don't know if the details you're looking for will be there. Most of these old tractors were heavily modified over the years, so "correctness" for anything would most likely have to come from a parts book (I ended up with one of those, too).
Mine just had the one large fuel tank also, since a previous owner had gone to gas instead of distillate, so the small tank originally used for gas has disappeared.
brownjp
03-29-2005 07:30:11
 Re: HELP with a 45 Slant Dash A in reply to 1945 A, 03-29-2005 06:07:14
That would be great if you could send me some pictures of yours That would help out. Does yours have shutters?
Will P
03-28-2005 19:14:36
Slant dash was made 39-47. Every tractor that had a battery had a slant dash. Probably about half of the 107,000 early styled A's built. had a slant dash. Search tractor photos on the left for pictures of the A's that you are looking for. Shut the fuel off and let it die. Best thing to do.
Will P
