4430 Rear wheels
Dean SW IA
03-28-2005 16:09:20
How many ftlb can I use on the pusher bolts to lossen the wedge??? Thanks dean
G/MAN
03-29-2005 13:35:25
 Re: 4430 Rear wheels in reply to Dean SW IA, 03-28-2005 16:09:20
Beating on the end of the axle is the usual method, but not the best method. The best is a piece of pipe long enough to slide over the axle up to the wedge, with an ID just bigger than the axle OD, and cut back halfway around it's diameter so you can beat directly on the wedge itself. I've seen the flanges break off of wedges before the wedge itself actually released.
K.B.-826
03-28-2005 19:33:08
Like Randy said, takes a big hammer and a lot of work. Don't be afraid to beat on that axle as hard as you can. Tighten the pusher bolts up after every few swings and eventually they'll pop.
Randy warren
03-28-2005 16:31:33
yes, you don't want to go to far on them they will break. if you get the tire off the ground and put a little pressure on them and get a big sledge hammer and hit the end of the axle as hard as you can to knock them loose. you need to take your main bolt's out that will help too. you can hit the axle a couple of time's and the tight them up a little more. good luck.
