410 or 410B?
Silverdice
03-27-2005 23:21:46
Just bought an older JD hoe. I'm not sure if it a 410 or 410B. The side says 410 but the metal plate says 410 B. The serial number best as I can read it says 1268891. Any help would be greatly appreciated since I am looking to buy a service and parts manual and don't want to get the wrong one. I hear they are two very different beasts. One more thing, this is my first rig, it runs fine but sure needs a little TLC since it has sat for a year or so, any other things to check other than changing the fluids and filters? Thanks
Jonathan in MA
03-28-2005 09:54:00
 Re: 410 or 410B? in reply to Silverdice, 03-27-2005 23:21:46
410 has a "square" looking cab and 2 shift levers in the middle of the floor. The 410B has a rounder cab with more glass. Has a shift lever on the floor and a forward reverse lever on the dash. There are 100's of other differences...but that may clear up identification.
Silverdice
04-01-2005 20:30:53
 Re: 410 or 410B? in reply to Jonathan in MA, 03-28-2005 09:54:00
Jonathan Thanks for the info... but I have both, two levers on the floor and a reverser on the dash. No glass anywhere, it is an open cab. I really lucked out. Bought the thing from a guy who was selling it for his cousin. Said it had some problems but didn't know what. I replaced the starter and a hydraulic line and the thing runs excellent. Only a couple things I'm trying to figure/work out. What type? for the manual (like I all ready mentioned) and the clutch. It only catches on the last inch or so when I let it out. Anyone know if this is simply a linkage problem (if so which way do I adjust)or am I looking at a bigger problem? Thanks again
Silverdice
04-10-2005 12:55:19
 Re: 410 or 410B? in reply to Silverdice, 04-01-2005 20:30:53
Jonathan, one more question if you don't mind. I was reading in some of the past forums, one in which you mentioned chattering hydraulics. Do you have anything further on this one. My main line coming off the pump chatters but nothing else, no vibration in the pump or anything. This doesn't seem to effect its operation that I know of, but then again I don't know what it runs like without the chatter.
