A oil pump boo-boo
railroadgoat
03-27-2005 14:23:59
Pulled the cover off my 1941 A to replace leaky gasket. The long shaft and gear came down with it. When I went to re-install, I heard something inside fall (tink). Now the gears just go round and round and don"t engage into anything. What did I do ?? How do I fix it ??
Marty Z
03-27-2005 21:54:54
 Re: A oil pump boo-boo in reply to railroadgoat, 03-27-2005 14:23:59
Just had my oil pump out and re installed. That long shaft that came out has a square end on it. It fits into a square coupling that is driven by the cam shaft. Mine also had a washer with a square hole in it that fit on the shaft before it goes into the coupling. When I dropped the shaft out I also heard a Tink" and it was that washer. My neighbor has the same "A" and he has no washer. I don't know what it is for but I put it back when I re installed it last night. Sounds like you need to get into the top of it and remove the oil line to the pump first. Then drop the oil pump housing, and screen will come with it. It needs cleaning any way. Scrape out all the old sludge through the big hole you now have and swoosh it out with some Kero... You will find what went Tink when you sift through your sludge.
Good luck... I also needed stubby wrenches for the oil line .
Marty Z
Jerry (KS)
03-27-2005 14:37:07
The coupling probably was stuck at the top and then fell off as you were reinstalling everything. Just "fish" it out with a wire and stick it back on the shaft.
railroadgoat
03-27-2005 16:05:45
 Re: A oil pump boo-boo in reply to Jerry (KS), 03-27-2005 14:37:07
The cover I removed had 4 bolts. Then the gears and shaft came out with it. Right above this is 2 studs and 1 bolt holding the oil pump housing, I think.. If I remove these does this bring out the screen ?? Does anything hold it or do I need to pry it out. Have gasket for it also. There is about 1 inch of sludge in the bottom of engine. Best way to get it out ???
Pat Browning
03-27-2005 17:09:49
 Re: A oil pump boo-boo in reply to railroadgoat, 03-27-2005 16:05:45
Pardner -- Me thinks you should halt! You need to have an I&T Shop Service Manual & a Parts Catalog -- or you will end up with a real Boo Boo! This forum is good, but it is no substitute for directions and a picture of what it is you are dealing with. Far too many folks out there think that because it is said the older tractors are simple -- they can overhaul them without a guide. 'Tain't so! I wish you well my friend, but surely, I would not delve into any tractor without knowing what was behind each piece I removed! (PatB)
railroadgoat
03-29-2005 20:36:01
 Re: A oil pump boo-boo in reply to Pat Browning, 03-27-2005 17:09:49
Got her all back together. I thought it was a piece of cake. Took top crank cover off, unhooked two lines to pump, dropped pump out bottom. Cleaned and cleaned the sludge out of crankcase, cleaned the well plugged screen, found the coupling and with the use of hydraulic jack got everything back in by myself. Fun job-- THIS TIME !!! I know next time may not be so easy. Thanks for your inputs.
Mike M
03-28-2005 05:46:11
AMEN. More truer words have not been written !
Mike M
03-27-2005 16:20:36
There are many oil lines hooked to the pump that you will have to unhook to get it all the way out. Take off the top plate covering your crankcase and work from the top,get some stubby wrenches.You are going to have to go in from the top to hook up that oil pump coupling anyhow.
