50 hydraulic leak.
Trump
03-27-2005 12:31:42
My 50 is leaking out of the bottom powr-trol dummy plug. I put 7 qts. of oil in it when I changed, thats what the manual said if using a remote cylinder. Are there o-rings in there that need replacing ? Any suggestions appreciated.
Brian-IN
03-27-2005 13:03:20
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 12:31:42
how bad is the leak?
Trump
03-27-2005 13:36:06
 Re: 50 hydraulic leak. in reply to Brian-IN, 03-27-2005 13:03:20
It's a constant drip,drip,drip. Lost about 1/2 pt. of oil last night. Looks like it's getting worst.
F-I-T
03-27-2005 13:58:05
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 13:36:06
third party image
Trump:
There are four o-rings, all the same part number. Buy extras so if you drop one you don't have to go looking for it.
It's not an expensive, but it is a pain, because you have to work throughh the small bores. A combination of forceps and bent wires will usually do the trick. Heating the wire tips to burn through the old o-rings so that you can get them out in pieces works for me.
Frank
Trump
03-27-2005 14:11:47
 Re: 50 hydraulic leak. in reply to F-I-T, 03-27-2005 13:58:05
Thanks Frank, I'll get a diagram printed out so I can get the right o-rings from Deere and also as a guide. Oh by the way heard anything from Clooney. Trump
F-I-T
03-27-2005 15:42:00
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 14:11:47
The o-rings are A 3190 R. Sometimes they have them in stock, but I think I had to order them the last time.
I think Clooney must still be working on an assignment that has kept him away from the computer for awhile.
Trump
03-27-2005 16:56:44
 Re: 50 hydraulic leak. in reply to F-I-T, 03-27-2005 15:42:00
Frank,I have several Deere dealers within a 100 mile radius available in my area. I'll get on the horn tomorrow morning and see what they got. I got a very good 50 but this dripping has got to stop,even thought about welding the dummy plugs in. This is a easy repair ,glad I don't have to take off the powr-trol unit. We would think Deere would have put the o-rings on the dummy plugs. I'm sure Clooney is keeping an eye on us. Trump
F-I-T
03-27-2005 17:37:02
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 16:56:44
Well, then they would have to maintain o-rings on the dummy's and each and every remote cylinder plug you pushed in there. This way, there's only oner set of o-rings ro replace.
I figure if you have to replace them every 50 years, it wasn't too bad a design.
Now, welding the dummy plugs to the box.....that would have been a bad design.
Trump
03-27-2005 18:56:26
 Re: 50 hydraulic leak. in reply to F-I-T, 03-27-2005 17:37:02
You are right about that.It just reminds me of my dads old D-14 with the remote coupling since the day it was new,it always leaked,there was no fix. I was thinking about using JB weld or some type of sealant,not using the arch welder,didn't mean to make you think different. But after fifty years I'm sure everything has a tendency to loosen up,including me. If the 50 was parked out on the dirt it wouldn't show up so bad, it's in my shop with concrete floor and I'm the one that does the floor's in there. And I do try to be a little conservative with the cost and supply of oil.
F-I-T
03-27-2005 19:37:07
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 18:56:26
Well, you'll love the low cost of the repair, but don't keep track of your time. I've already spent upto 8 hours off and on working to get them installed.
Trump
03-27-2005 19:56:01
 Re: 50 hydraulic leak. in reply to F-I-T, 03-27-2005 19:37:07
If it took you 8 hours it will probably take me 24,counting time taking pictures of Rover (my dog) barking at the apple tree. o-rings are easy,I'll be getting another cortosone(spelling not correct) shot in my neck sometime within a week,this will take the pain out of my right shoulder. How was the citrus crop there last year? Trump
F-I-T
03-27-2005 20:21:59
 Re: 50 hydraulic leak. in reply to Trump, 03-27-2005 19:56:01
No citrus up where I live. mostly hay and cotton.
