'72 4020 SCV/breakaway overhaul
Glen Anderson
03-27-2005 06:43:48
I'm in the process of re-sealing the breakaway/coupler portion of the SCV valve on our '72 4020. The repair/overhaul kit from John Deere comes with both o-ring/back-up ring and lip type seals for the SCV housing to seal the barrel(terminoligy?). Which set up works best? o-ring or lip seal?
matthies
03-27-2005 19:29:06
 Re: '72 4020 SCV/breakaway overhaul in reply to Glen Anderson, 03-27-2005 06:43:48
The orings will seal better but sometimes they make the barrel hard to move(coupling and uncoupling hoses). The lip type seal don't seem to last long. I only put in the oring/backup rings myself. Put one side lip and the other side oring and you make the call. You'll know once you slide that barrel which ones you like. good luck chris
msb
03-27-2005 08:53:50
Personally,I still like the o-rings best.But I am sure ther will be others who disagree with me.Neither will last long unless the tips and the couplers aren't kept clean.I use a spray can of WD40 to flush the couplers out before I insert the hose tips.
Glen Anderson
03-27-2005 11:03:16
 Re: '72 4020 SCV/breakaway overhaul in reply to msb, 03-27-2005 08:53:50
Thanx for the reply. However I think we have a mix up, I'm not referring to the seal or o-ring that seals the the male portion of the coupler(the hose that operates a cyl for example)to the female portion that is mounted on the tractor. I'm referring to the 2 seals or o-rings that are located in SCV housing that seal the coupler barrel(for a lack of better words.)
Glen Anderson
03-30-2005 21:46:47
 Re: '72 4020 SCV/breakaway overhaul in reply to Glen Anderson, 03-27-2005 11:03:16
Thanx for the reply Chris, I wish I'd have read it earlier. Initially I used the lip type seal as specified in the "instructions" that came with the break-away overhaul kit. After testing the hydraulics, one barrel on each SCV developed a small leak....GRRRR! So I ended up taking the valves off again and replacing the lip seals with the o-rings/back-up rings. Re-tested no more leaks.
One thing is for sure, I'll sacrifice the coupler being a little stiff over a leak any day! :)
