Dave NE IA
03-26-2005 20:34:27
Just did a carburator rebuild on DLTX 71. I found numerous errors on preveous attempts to rebuild. The guy says the only way it will idle now is with the idle jet turned completly out. Otherwise it runs like a million dollars at full throttle. It idles slow enough to walk completly around tractor between pops----with the idle jet turned almost completly out. This kind of hurts my pride as to date it was 100% on the rebuilds. The carburator was totaly glass beaded, all air passages drilled, blown out, new drill plugs, a recent new float, vents, gaskets,all retaped threads, new welsh plugs except the extremly tiny tiny one,new throttle bushings top and bottom and resized. New nozzle spring, needle seat, throttle shaft, strainer,as well as float bearings. The only thing that seemed questionable is the passage behind the vents. The nozzle cleanned up real good, the carburator was a big chunk of rust, but seemed to clean up with the glass beads real good. Someone else had pulled the nozzle, and I do not recall a bigger hole in the bottom of the nozzle. The throttle plate seemed to be perfectly round and new not to long ago. The idle double set of 2 tiny holes were plugged pretty tight, but were drilled out. Perhaps another piece of rust inside the passages moved?? Others have worked on this carburator numerous times, and I apparently have a brain cramp. Thanks in advance. Dave NE IA
