4430 trans
rs1
03-26-2005 19:49:15
Looking to buy a 4430 that will not shift into one of its ranges. Wondering if anyone has had this problem or knows about how many shop hours it would take to repair? The price is good and can afford to put some work into it.
G/MAN
03-28-2005 07:37:31
 Re: 4430 trans in reply to rs1, 03-26-2005 19:49:15
The first thing to do is determine the problem. It could be a relatively easy fix of a major problem. Nobody can give an accurate estimate without knowing the problem.
MSM
03-27-2005 04:25:58
Figure cab or platform off,double split of trans,plus parts which run about $900-$2000 per range depending on damage done,the other ranges should be checked and freshened up while apart,misc.seals,bearings,gaskets oil and filters.Parts should run in the $3000+ range.Probably take 20-30+ hours of shop labor with someone knowing what they are doing.If it is an early tractor and the trans and rear updates weren't done it could be considerably more.
