2510 diesel problem
Capecos
03-26-2005 17:50:08
I have a 2510 diesel with the DBG pump. Problem is, it starts easy and runs like a champ for about 5 or 10 minutes, then acts like it's running out of fuel and dies. I crack the hex screw on the side of the injector pump and it clears up as diesel squirts out. Any ideas of what causes this. It just started this after sitting for about 6 or 8 months. Help appreciated.
jdemaris
03-27-2005 15:31:06
 Re: 2510 diesel problem in reply to Capecos, 03-26-2005 17:50:08
As MSB stated, it's probably the governor weight retainer dampening ring. The housing-pressure regulator/check valve on top of the pump is probably plugged with debris. It's the fitting where the return fuel line hooks. If you know someone that has experience on Roosamaster pumps, it's an hour job to take the pump apart and fix it. Takes about $45 in parts (not including time of removing and reinstalling the pump). You'll probably get by with a seal kit for $28, a new drive-end bronze bushing for $10, and a new housing regulator/check valve fitting for $7. The seal kit comes with a new OEM style dampening ring, all o-rings and seals, driveshaft umbrella seals, banjo washers for the fuel lines, and an updated transfer pump fuel pressre regulator plug. The new style weight retainer with rubber snubbers instead of the original one-piece ring adds another $40. Most shops will tell you it's not necessary. Who knows? The ring that fails gets hard and brittle and finally shatters. These failures got a lot of attention when General Motors used the same setup in the 1978 diesel pickup trucks. With the higher underhood temperatures, the rings didn't last a year. So, Roosamaster/Stanadyne updated the materials. The materials used are now different and are supposed to last a lot longer. It seems to be true. I know of some that I intalled over 20 years ago that haven't failed yet.
jdg from hbmi
03-27-2005 08:46:41
Sounds to me that if you bleed off presure the when it is running or even not running and then it runs good for a few minutes you have a blocked fuel return line back to the tank.
Capecos
03-27-2005 23:19:57
 Re: 2510 diesel problem in reply to jdg from hbmi, 03-27-2005 08:46:41
Thanks, hbmi. That's what I thought, too. I removed the return line at the fuel tank and got some fuel. Should there be any more than a steady flow? It's not a lot of volume, but it's steady.
msb
03-26-2005 17:59:31
Sounds like the govenor weight retainer seal has come apart.Remove the return line fitting in the pump.If you find small bits of plastic then you know for sure that is the problem.Nothing to do but have the injection pump rebuilt.Ask your rebuilder it install the newer govenor weight retainer that no longer has the plastic seal.
