G heads:
jdg from hbmi
03-26-2005 14:34:02
I have a 1950 G with a factory head . Can I get more power out of it by grinding .250 off of the factory head or by installing a (flat head). The engine is bored .125 oversized.
JD720
03-26-2005 18:49:47
 Re: G heads: in reply to jdg from hbmi, 03-26-2005 14:34:02
You can get more power out of the flat head but if you already have high compression pistons you will be stuck running premium gas.You could cut the tops of the pistons down a little to get the compression down.It depends on what you plan to do with the tractor and how much you really want to spend doing it.If it were me I would shave the head down .250, give it a good 3 angle valve job,clean the ports up a little and be happy.Also keep in mind there is power to be gained by matching the gaskets and the manifold ports to the head.
