Changed the gear oil and here's what I found:
Kurt_JDB
03-26-2005 13:23:58
I changed the transmission/rear axle oil on my recently aquired "51 "B" tractor and am concerned about what I found in the oil. After Draining out the gear oil, I put my finger in the large rear axle drain hole, and was able to wipe out numerous bits of metal from the bottom of the case. Looking at my fingers, I could also see what looked like brass filings in the oil. I put some kerosene in the bottom of the bucket I had drained the oil into, and I could see that the bottom of the bucket was loaded with these very fine filings. I put a magnet to it and these filings just jumped up out of the oil/kerosene mixture. They are extremly fine filings, but there seems to be a lot of them. Other than the filings, the oil did not seem unusualy dirty or milky.
The transmission and rear end do not seem to make much unusual noise, and seem to function properly, but I am concerned about this and would like some advice about what to do next.
Should I flush out the transmission with a solvent as recommended in the service book? the book recomends running the tractor with 3 gallons of flushing oil (what ever that is).
Is there some inspection or test that I can do to determine the source of the metal?
Thanks in advance,
Kurt
Ben.So.Tex
03-26-2005 15:26:31
 Re: Changed the gear oil and here's what I found: in reply to Kurt_JDB, 03-26-2005 13:23:58
Kurt. Drain the oil and put about 4 gallons of diesel and a gallon of 30 or 40 weight oil and then drive it around for about 20 mintues and then drain this should clean it out preety good. I did this to a 60 that was under water for two days from a flood and it worked good for me,, the only thing I did different was that I flushed it out twice,too include the engine at a different ratio more oil than diesel,, YES FUEL COST IS HIGH, but cheaper than than a tear down,,Good Luck Ben
Mike M
03-26-2005 15:01:31
It depends on what you intend to do with the tractor ? You may be farther ahead to do as John T says and run it ,and listen for wierd stuff. On the other hand I have never seen an old 2 cyl. tranny ( or any other part of the tractor )that I couldn't find problems if I went looking for them. These old things can run and run with all sorts of problems.
Kurt_JDB
03-26-2005 15:25:01
 Re: Changed the gear oil and here's what I found: in reply to Mike M, 03-26-2005 15:01:31
Mike, I don't plan to use the tractor for heavy work, I bought it because I am interested in old machinery, and my brother can use it for his garden.
However, I am into putting this machine into good repair with the hope it will survive for the long term when it eventually passes from my hands.
'nuff said.
Kurt
xragman
03-26-2005 14:49:02
listen to john t .he is seldom wring. change oil again next year,& check it again.
John T
03-26-2005 14:19:34
Kurt, this isnt the scientific or exact answer youre lookin for, hopefully some knowledgeable people in the field will weigh in, but this is just based on experience. I dont recall changing that gear oil, especially after its not been changed in years, and NOT finding at least some metal and/or brass in the buckets bottom or up inside the case. I have pulled those plugs and nuttin at all came out till I stuck a screwdriver up inside to break loose the crud and then usually you get a certain amount of nasty water first.
I usually use Diesel fuel to flush n drain them out and not worry too much unless I found like gear teeth etc., but if any teeth are missing you ought to be able to hear that tell tale clicking or clunking.
Unless it were making wierd noises I would just be tempted to flush her well with Diesel then re fill her and keep an eye and ear open.
Thats all I have to say about that
John T
Dave 2N
03-26-2005 16:22:03
 Re: Changed the gear oil and here's what I found: in reply to John T, 03-26-2005 14:19:34
"Ditto" to what John T says. This has been my experience too.
Kurt_JDB
03-26-2005 15:03:17
Thanks for the reply, John T. When you flush out the case, do you run the tractor around for a bit or just let it sit a while?
Kurt
John T
03-26-2005 16:38:03
 Re: Changed the gear oil and here's what I found: in reply to Kurt_JDB, 03-26-2005 15:03:17
I wouldnt run her too much on just straight Diesel or Kerosene unless you mixed it with some lighter weight oil. If you do that and another Diesel flush she oughta be in pretty good shape I would think
John T
Packard8
03-26-2005 16:34:51
You can jack the rear wheels up off the ground and run it in all fwd gears & rev for a short while to circulate the flushing fluid without putting much strain on the gears & brgs. Then let it down and pull the drain plug and let it drain overnite (make sure its on a bit of a slope towards the drain plug). I've done this on old cars a few times and was suprized at the crud that came out.
On the other hand, I have an old B that hasn't been touched in 40 years and it just keeps going & going. I'm afraid to flush it out cuz maybe it's the crud that's holding it together!
mark
03-26-2005 17:18:43
 Re: Changed the gear oil and here's what I found: in reply to Packard8, 03-26-2005 16:34:51
I had an old AC "CA" and it had magnets built into the drain plugs (great idea), everytime I pulled a plug there would be a gob of metal attached and that magnet was put there to catch it....so it"s normal.
If I was going to flush, add some alcohol....like dry gas...to your diesel or kero, that will absorn any latent water in there as well. Drive it around the yard/driveway long enough for everything to slosh around and then drain/refill. You"ll okay.
