JD 60 PS under pressure - when eng is off -
Tom in Jersey S
03-26-2005 07:30:32
This may be a dumb question - but I've never encountered a PS system that was under pressure even when the engine was off - Here's the story...My PS leaked on my 60, so we put some hydraulic fluid in it to find the leak, repaired the leak (new seal) and then went to drain the fluid. I forgot to turn the wheel hard left like you're supposed too. I open the drain plug and fluid shot out about 6 inches - I could definitely "hear" pressure behind the fluid as I pulled the plug. Interesting enough since the tractor hasn't been started in 2 days. Once I drained the fluid I refilled the unit with JD PS fluid -ran the tractor for 1 minute and shut down. Then noticed there is pressure there when I take the fill cap off... is this normal?
Also the JD fluid is slightly diluted by the hydraulic oil - is this a problem?
Sounds like I'm full of problems - doesn't it?
Thanks
TOM
F-I-T
03-27-2005 08:59:35
 Re: JD 60 PS under pressure - when eng is off - in reply to Tom in Jersey Shore, 03-26-2005 07:30:32
Tom:
You do have several different issues.
Well, that can happen. The drain is in the bottom of rotary cylinder, and if the spool valve is sitting in the right (sealed) position, and the vanes seals are working, you could have pressure in there for quire a while.
Well, there is some presure that will come as a result of heating of the oil. To relieve that, there is a sintered brass vent plug, about the consistency of an older GM carburetor fuel filter, located in the top plate of the dipstick, that is expected to allow air to pass both ways. Over the years these can get occluded with grease, paint, etc, and no longer function as intended. You can try to rejuvenate it by soaking it in some lacquer thinner or other suitable solvent, then use a bit of compressed air on it. On extreme occasions, you can either try to replce the element with a piece of sintered brass or by a new dipstick from your dealer. A lot of pressure could mean you have a suction side air leak.
Since the drain plug is not located in the very bottom of the P/S cylinder, you probably had nearly a quart retained amid the vanes in the rotary cavity. Unless it acts poorly, it shouldn't not matter, but I'm a stickler for using the original JD oil in the P/S system.
TP from Central PA
03-26-2005 10:51:08
Can"t help you on the 60, the one I ran had a Charlynn setup on it(Aftermarket)..... ....Anyhow, I was just wondering how you like the old girl?
CLW
03-26-2005 09:36:59
Tom, check and see if the vent hole in the fill cap is pluged. I know the 630 has the vent, the 60 should also.
CLW
Brian-IN
03-26-2005 07:49:03
sounds like you over filled it to me.
Tom in Jersey Shore
03-26-2005 07:54:26
 Re: JD 60 PS under pressure - when eng is off - in reply to Brian-IN, 03-26-2005 07:49:03
Brian -
I forgot to mention that there was very little hydraulic fluid in it - So little that it didn't even register on the dipstick.
zachary
03-26-2005 13:10:08
 Re: JD 60 PS under pressure - when eng is off - in reply to Tom in Jersey Shore, 03-26-2005 07:54:26
sounds to me like you have a restriction in one of your lines i would check all lines for kinks and damage and go from there
Tom in Jersey Shore
03-27-2005 11:20:50
 Re: JD 60 PS under pressure - when eng is off - in reply to zachary, 03-26-2005 13:10:08
Thank you for the responses. I'm going out to check out the dipstick right now.
TP - As for how I like the tractor --- I LOVE IT.
I wouldn't trade it for anything else. It runs great and I hope to be able to use it for a lot of chores when we get out on our new property next month.
Regards to all,
TOM
