Clutch/Smoking
hjcrisman
03-25-2005 16:17:27
Have 1948 JDB. Engine running and the clutch is dissengaged and trasmission is in neutral, have smoking coming around housing. As soon as clutch is engaged, all smoking stops. What is wrong and what should be done to correct situation?
John Van Valkenburgh
03-27-2005 00:28:12
 Re: Clutch/Smoking in reply to hjcrisman, 03-25-2005 16:17:27
The clutch has a bearing that is active when the engine is running and the clutch is not engaged. Because of this bearing, JD recommends that you put the transmission in neutral and engage the clutch if you are going to run it for more than a second here or there. The bearing will eventually need grease and should be serviced at some time.
Are you seeing smoke or it is perhaps dust? These old clutches get a lot of dust build up inside over the years. Are you hearing any squealing or grinding when its disengaged?
How does the clutch work? Does it snap in/out okay? Any slipping under load in the higher gears?
Best of luck,
John
1953 Model 50
Miss b havin 36
03-26-2005 17:10:40
Its been our experience you could have some engine blow by if the vane pump is not right in the fan shaft.
buickanddeere
03-25-2005 19:57:58
In your operators manual it tells you not to idle or run the tractor with the clutch disengaged. Put the trans in neutral and engage the clutch. There is a service interval for removing the pulley and cleaning/repacking the bearing. How long would you run a modern tractor with the clutch pedal pushed down and spinning the throwout bearing?
Mike M
03-25-2005 19:29:49
Hard to tell without listening to it,and feeling how the clutch is working. I would start by makeing sure that when it is disengaged that it is actually disengaged and that the pulley brake isn't coming on too soon,or coming on too late and pinching the back facing.
