1945 JD B Carb Problems
desso15
03-25-2005 16:10:35
I have a 1945 JD B I have troubles with the float sticking and filling the cylinders up with gas, what could be wrong? I have had the tractor for about 5 years and it did it when we first got this tractor and we had a carb kit installed with new gaskets and needles and seats and haven"t had a problem since, till last saturday i got it out and it hadn"t run scince last fall, it fired right up ran for about 5 min and flooded out pulled the plugs and full of gas, drained the oil put new oil and filter in and tapped on it and it ran fine for 2 hours then parked it went to get it out of the garage and the battery was dead so we tried to pull start it today and gas came out the exaust pipe, can"t figure it out it ran fine last time we had it out and we keep the fuel bowl shut off when we are not running up. What is causing the cylinders to fill up with gas? You could e-mail me or leave a post here. Thanks in advance for all your help. Jon
Mike M
03-25-2005 19:38:42
 Re: 1945 JD B Carb Problems in reply to desso15, 03-25-2005 16:10:35
The others have covered the float checking. Also check the gasket surface where the needle and seat seals sometimes they are eroded away and cause a leak.If you have one of the original type fuel shutoffs with the tee handle,or an all fuel valve these are not a positive type shut off and seep fuel by them thus you are still filling up when shut off. More bad news for you I have seen many a tractor have a bent connecting rod from tow starting with cylinders full of gas.I hope yours survived being tow started.
John T
03-25-2005 17:30:11
Desso, my moneys on either the needle valve is sticking or the floats a leaker, but Im gonna go with a sticking needle for now. Ive had em set not too long at all and gum n varnish makes the needle sticky and it cant raise to shut the gas off, either that or theres some dirt in the seat. If tapping on the carb makes her okay, I suspect gum or varnish or dirt in the needle n seat area. You can remove the carbs side inlet strainer lil side plug and use gumout to try n clean any gum or varnish out or if that dont help you can remove the side inlet strainers top nut n cap (may need a new gasket) and then clean out the needle n seat area down there in the bottom center with gumout etc.
If the needle n seat or dirt in it isnt the problem, you could remove the carb bowls bottom drain plug and screw in a lil hose barb and use clear plastic tubing held above the bowl level and turn the gas on and observe at what level the gas is actually rising to in the bowl.
If you suspect the float, when removed if you carefully shake it n listen you may hear gas sloshing inside it if its a leaker. (sinks to bowls bottom never rising to shut off the needle) If removed you can place it a cup of water and heat the water and see if air bubbles come out meaning shes a leaker and sinking to the bottom
I always turn the gas off just to be safe anyway. I tend to use Sta Bil Gas Stabilizer year round now plus add a lil low ash 2 cycle oil to the gas which I think might prevent rust by leaving an oil film in the carb PLUS may help as a top end valve lube.
Let us know, Good luck n God Bless
John T
BMAN
03-25-2005 16:36:43
Could be the float. I had a rebuilt carburetor with a new float and 6 months later the soldier devoloped a leak. Take the float out and shake it to see if its full of gas.
Dave NE IA
03-25-2005 16:23:08
You probably have a weeee speck of rust on the needle valve, or perhaps the float is actualy sticking. My money is on the first option. Try draining the carburator for a few munites, while tapping on the carburator --use common sence while beating on it. You are trying to flush the speck of rust through the needle valve. If this does not work, pull the fuel inlet off the top of the carburator, then remove the needle valve seat. Again maaaay be the rust will flush through. More than likley your owners manual will tell you to shut the gas off if stopping the tractor overnight or for a extended time frame. Dave NE IA
