John Deere H hydraulics
amg_520
03-25-2005 14:12:23
I was wondering how hard it would be to change a non hydraulic h over to a hydraulic one using the john deere pump. Could I just change the pump that attaches to the governor housing or is there more too it than that? Thanks
Mike M
03-25-2005 19:44:02
 Re: John Deere H hydraulics in reply to amg_520, 03-25-2005 14:12:23
First you have to have the long gov. shaft to drive it.Second you need to put the correct amount of shim gaskets in there so you don't screw up your fan gears. If you have never had your governor off and checked it there is a good chance it needs attention anyhow and you can do all this at one time and set it up correctly.
F-I-T
03-25-2005 14:20:43
WEll, you'll need to install the longer governor shaft that drives the Power-Lift unit as well. I think the balance is bolt on.
Frank
dan_41jdh
03-25-2005 14:27:18
 Re: John Deere H hydraulics in reply to F-I-T, 03-25-2005 14:20:43
Actually, the longer shaft (H864R) became standard with s/n 27000, so the power lift unit will bolt right on, as a replacement for the left bearing housing of the governor. Before that serial number, the short shaft (H388R) had to be changed.
