Hot 2550
onefarmer
03-25-2005 08:48:32
I have a 2550 JD that has Hyd trouble. The Hyd work fine when cold then gets extremely hot and losses pressure. This is just during light use like raking hay. So I know its not from slipping clutches or heavy use. The cooler is clean. The front pump seems to work correctly. But the rear end and hyd oil get very hot. Anyone have any ideas?
Walter Squires
03-25-2005 11:06:35
 Re: Hot 2550 in reply to onefarmer, 03-25-2005 08:48:32
The o-rings are blown in 3-point control valve is usally the culpret.
onefarmer
03-25-2005 12:52:08
 Re: Hot 2550 in reply to Walter Squires, 03-25-2005 11:06:35
Sounds like a good possibility. Would the o-rings leak make a differance if the three point was up or down or would they be under the same pressue either way?
G/MAN
03-25-2005 13:38:51
 Re: Hot 2550 in reply to onefarmer, 03-25-2005 12:52:08
Actually it could be a leak just about anywhere in the pressure side of the hydraulic system. That tractor has a constant-pressure hydraulic system, meaning that any time the engine is running, you have in excess of 2000 psi of hydraulic pressure waiting to do some work. Any internal leak point acting as an orifice for that 2000+ psi to flow through is going to heat the oil. Going around the tractor with a digital thermometer gun might help you pinpoint just where the leak is.
