JD M No oil to head
AH
03-24-2005 21:31:41
Conpleted engine overhaul on Model M, 1948. Started engine with rocker arm cover off to make sure head was getting oil. No oil. Has new oil pressure gauge that reads high, removed galley pipe plug located near oil filter,oil gushed out when engine fired. However, but no oil comes out the opening with the oil line (part #AM753T) removed at the block. When I apply oil into this opening in the block the oil leaks down. Any ideas as to problem or solution? Thanks
Wayne in Tn.
03-25-2005 04:45:13
 Re: JD M No oil to head in reply to AH, 03-24-2005 21:31:41
Start the engine up with the oil line removed from the block. If no oil comes out, then the cam bearing is not installed correctly. If oil does come out, then remove the rear rocker arm stud that goes through the valve cover. This stud has a flat place on the side of it to allow oil to the rockers. Its possible this stud was installed at the front of the engine.
AH
03-25-2005 05:56:59
 Re: JD M No oil to head in reply to Wayne in Tn., 03-25-2005 04:45:13
Thanks for all comments. Looks like I will have to pull engine down and check cam bearing alignment.
Jim Dunn
03-25-2005 03:36:40
I once had an aftermarket head gasket that didn't have the oil passage hole and I didn't pick up on it. Are you sure yours was the right gasket and no passages blocked?
marvin
03-25-2005 03:29:21
i should have said rocker arm bolts
Mike M
03-25-2005 03:24:57
Did anyone have the cam bearings out ? The rear one has to line up perfectly to an oil hole.
marvin
03-25-2005 02:24:58
swap places with your head bolts
mbptractor
03-25-2005 07:41:33
 Re: JD M No oil to head in reply to marvin, 03-25-2005 02:24:58
its more than likely the rear rocker arm stud bolt is not alined correctly. seen it happen several times each time this was the problem.
AH
03-25-2005 19:26:21
 Re: JD M No oil to head in reply to mbptractor, 03-25-2005 07:41:33
I ran a line from the pipe plug located near the oil pump to the head. Oil came out at the rocker arms just like it should. Thus, I think I have a cam bearing problem. Thanks for all comments
