430 U PTO
Hayfarmer
03-24-2005 20:04:59
Removed PTO from my 430 as it moved in and out for some time. Suspected the snap ring and was correct but also needs bearings. The rear part is sealed on both ends and according to operator"s manuel you fill it with 80 wt oil. The check plug is under the master shield so not real handy and I never relaized it was there. Don"t think anyone did for it"s life. Front bearing is sealed. A small seal between the 2 parts keeps the oil in the rear and that seal is no longer available from Deere. It sounds like the standard practice on these PTOs was to remove them when not in use for a time. It came with the block off plate to put over the PTO opening when removed. I think I will pack the rear bearing with heavy grease when I put it back together as I don"t think the oil will stay in. Kind of an odd setup for Deere especially with the check plug under the shield and in accessable. Has anyone else worked on one of these before?
Lavoy
03-25-2005 08:37:54
 Re: 430 U PTO in reply to Hayfarmer, 03-24-2005 20:04:59
Both seals are current from Deere.
AM253T subs to T22069-$686
AM2553T-$6.36
Lavoy
Hayfarmer
03-25-2005 20:24:52
 Re: 430 U PTO in reply to Lavoy, 03-25-2005 08:37:54
Thanks for the info. My JD dealer is usually pretty good with subs but didn't find the T one. Assume it really isn't $686 as that sounds like an IH. Ordered the narrow one from NAPA today but it comes from Kentucky and since we are in Washington will take a while. It is amazing really that the shaft was still ok with all the years it has probably not had oil. My uncle ahd it before I did and I doubt he ever read the operator's manuel. Now that Iknow there is a place to oil will check it. Not handy as you have to remove the master shield to get to it. May just take it off in the winter as I use the tractor but not PTO then.
Dieselrider
03-25-2005 03:24:08
Buickanddeere is right, you should be able to find the correct seal and bearings at a bearing supply house.
buickanddeere
03-24-2005 21:09:46
The grease will work out of the rollers and they will run dry. The seals and bearings are generic off the shelf items. I was into the pto stub on my 435 after busting the snap ring while lifting the snowblower under load. The snap ring is easier to break than making the pto shaft telescope under heavy torque. The splined coupling was getting worn so a fresh one was installed as well.
