Correct All Fuel Manifold description?
JDVan
03-24-2005 16:30:25
A friend of mine has asked me to sell a 1949 JD B Manifold (B2179R) for him
on eBay. He described it as a 1949 "All Fuel" B manifold. After studying the
B Parts catalog, I"m not sure that is a correct description.
The Parts catalog shows this manifold used serial # (B183972-B200999)
whereas a gasoline manifold for the serial number range (B96000-B200999) as
B2803R. The B2179R manifold ALSO shows as a valid sub for B1786R on ser #
(B96000-B183971). I"M CONFUSED.
Could someone explain this to me so I"m no longer confused?
Here is my present thinking. This "all fuel" manifold could be used from
1941 models all the way through the later "all fuel" tractors through
B200999. Which would be in the early part of the 1947 model year. B2282R
"All Fuel" manifold was used from then on. So I think this manifold never
was supposed to be on a 1949 B. Help ????
Duane Larson
03-25-2005 06:55:03
 Re: Correct All Fuel Manifold description? in reply to JDVan, 03-24-2005 16:30:25
JDVan,
Well, I'll take a shot at it. The B manifold had a tin shield over it, starting at 96000, to improve the operation in cold weather using distillate fuels. This cover had a habit of rusting through. The November 1944 FSB notes this problem and announces the shield can now be bought separately as p/n AB3294R. However, one can guess this was not too successful - manifold bolts are not the easiest to remove to replace the tin shield and probably resulted in lots of broken bolts. It appears to me that further manifold design work was done to get rid of the need for the tin cover, and this was accomplished with introduction of the B2179R manifold near end of production of the "middle" B at 183972. Parts catalog PC-RB1-(3-48) notes the tin cover was no longer sold and the manifold using it was to be replaced by the B2179R, which did not use the tin cover. I'm not sure what the physical difference is in the two manifolds - some B expert may know. So the tin cover sales lasted only a few years. A NOS tin cover would be a neat piece.
I agree this manifold was not used after 201000, according to any of the parts books I have. So, it would be a rather unusual piece, having a short period of use (183972-200247, last middle B made according to J.R. Hobbs book).
JDVan
03-25-2005 18:17:10
 Re: Correct All Fuel Manifold description? in reply to Duane Larson, 03-25-2005 06:55:03
Duane:
Thanks for the detailed response. We will never know how many of the B2179R ended up being retrofitted on the earlier tractors. I agree that removing exhaust manifold bolts to replace the tin or even to substitute manifolds was probably a risky task, at best, and I suspect alot never got changed because of it. Probably were running on gas anyway most if not all the time.
Do you happen to know if this manifold would work on the heads after serial number 201,000? Ther owner is adamant that it came off of a 49B, but the tractor was totally salvaged and now there is no way to really prove it. I suspect maybe an error was made in the model year identification. But...
Duane Larson
03-25-2005 19:51:54
 Re: Correct All Fuel Manifold description? in reply to JDVan, 03-25-2005 18:17:10
JDVan,
It would bolt up to the head, as the manifold gasket is the same number for both above and below 201000. So, assuming there is no interference with other components, I suspect it would work on s/n 201000 up. Probably a retrofit though, for whatever reason.
