G Clutch trouble
JLG
03-24-2005 13:45:07
I've just put new clutch disks in my "G". But now I cant get the nuts tight enough to keep the clutch from slipping. I noticed when I reassembled the clutch and put the 3 adjusting nuts back on that they seemed to have to be on too far (far enough that I'm past the cotter pin holes, which has to be wrong). My first thought was that I forgot a disk or other part, but I checked and its all there. I did have the pulley and side cover off the engine to put in a new cam. But as far as the clutch goes I put it back how I took it apart, but with new disks. Any ideas as to what I could have missed, or should check? Thanks for any help.
JLG
03-25-2005 15:03:13
 Re: G Clutch trouble in reply to JLG, 03-24-2005 13:45:07
Pulled the clutch back apart today and John VB was right. The floating disks are the same thickness, but the cast disk and the one that has the floaters rivited on are significantly thinner than the originals. I never even thought to check that when I put it all together. All these parts were aftermarket,half the price of Deere, but evidently you get what you pay for in this case.
John VB
03-25-2005 05:49:12
I'm pointing out the obvious, but are the new discs as thick or thicker than the originals?
Ben.So.Tex
03-24-2005 18:14:39
I will be watching this post because I am having the same problem with my G hope there is a life saver out there. Ben
