430 W TOM
Dave - Ia
03-24-2005 07:35:51
I am going to remove the TOM from my 430 today to put seals in the rockshaft. My tractor is a later one with bushings. Does anyone have experience with removing the old bushings and replacing them? The service manual does not cover this procedure. Do the bushings have to be pressed out or just driven? Thanks for any information you can give me.
Wayne in Tn.
03-24-2005 15:51:37
 Re: 430 W TOM in reply to Dave - Ia, 03-24-2005 07:35:51
Dave, those bushings can be driven out. The ideal way is to use a bushing driver the correct size. If you don"t have one, find a socket or pipe the same size as the bushings.
You are lucky to have the late model with the bushings. The older ones are almost impossible to stop the leaks. Don"t forget that bushing inside the hollow shaft.
Dave - Ia
03-24-2005 19:38:19
 Re: 430 W TOM in reply to Wayne in Tn., 03-24-2005 15:51:37
Thanks for the reply. I can come up with something the correct size and if I have to I maybe get it in the press. I just don"t want to break anything. I got the TOM on the bench but have not started taking it apart yet. Parts are suppossed to be here tomorrow. If I have any problems I"ll post again. Thanks again.
