50 Head Gasket Seeping
kman
03-23-2005 19:01:46
I noticed this winter when plowing heavy snow my 50 was seeping a little coolant out around the top of the head(it was under load somewhat). My concern is could it be also leaking somewhere else and getting into the crankcase? Is it possible to tourque the head or do I have to take it off and get a new gasket?
John Van Valkenburgh
03-24-2005 18:25:00
 Re: 50 Head Gasket Seeping in reply to kman, 03-23-2005 19:01:46
I think Bob has a good idea. If there is coolant in the engine oil it will settle to the bottom of the oil pan and be the first thing out the drain hole. I'd check for that before retorquing the head. If you are getting coolant in the engine oil I'd want to pull the head and check for cracks.
Best of luck,
John
1953 Model 50
Mike M
03-24-2005 03:37:05
I don't like the style of head gaskets used in these old JD's. I have had a few seapage problems with new ones. If yours is old it could be bad,I would retorque it and put in a big bottle of bar's leak right before you work it hard next time.
Bob
03-23-2005 21:41:35
It certainly wouldn't hurt to try retorquing it.
Slightly loosen the crankcase drain plug after it has sat unused a couple of days, to see what drips out first, to be sure there's no coolant leaking into the crankcase, though!
