Brake disassembly
Greg F
02-19-2004 13:03:50
I have searched the forum and have come up with some great info on tearing down and putting brakes back together for a Model A but need further assistance. The brakes I have were taken off the tractor by the three bolts and brought inside to work on. I have read basically two methods for removing the drum and getting the spindle out. Taking the cotter pin out and the nut off on the tractor side then putting the nut back and dropping the unit on a piece of wood or hitting it with a hammer. I think my main problem is the brake adjustment bolt as I can not get that thing to move at all. I am really afraid to put to much force on it but any tips or tricks you fellas have to get things apart would be greatly appreciated.
Thanks
Greg F
Robert
02-20-2004 07:41:07
 Re: Brake disassembly in reply to Greg F, 02-19-2004 13:03:50
I had a lot of the same troubles when working on the brakes for my '45A. The adjustment bolts were really tough, because they had literally rusted in place. My solution was to put LOTS of good penetrating oil (not WD-40, although it smells good, LOL), and then just working the nut back and forth. Part of that problem with the adjuster is it's shape, and the pins that ride on it are also usually rusted in their place (at least, mine were). Again, lots of penetrating oil and patience.
When I finally got all everything apart, I went back together with lots of never seize.
I got the necessary parts I needed from sharp's. Email me direct for their address, if you wnat or need it.
GOOD LUCK!
Greg F
02-20-2004 17:18:52
 Re: Re: Brake disassembly in reply to Robert, 02-20-2004 07:41:07
Robert thanks for the info. I can not email as the system hide your emil. Please sent the info to [email protected]
Thanks
Greg
KB
02-19-2004 14:58:08
We had the same problem on our 60 and we ended up putting the whole thing in the press and pressed the drum off and then you can really soak the adjuster threads and the sliders inside and then they will come apart fairly easily.
John T
02-19-2004 14:45:55
Hi Greg, I can tell you things I would try and hopefully others can add different ways how they did it and maybe you can get that adjuster to turn. Take a torch and apply heat however/wherever much as possible you can get to NOT TO THE BOLT but all around it to the area in which the threads are embedded. I would have a wrench on the bolt and then hammer the wrenches end and see if she dont start to turn out loosening. I dont like to use a hard dead pull, but a vibrating hammer shock. You dont want to get the bolt too hot, it may soften and twist off. If you heat the bolt, let cool so its not soft before applyign too much force.
The drop on a board as you mentioned or use a block and hit it with a hammer are ways to get it apart. Onec apart, clean and wire brush all the pins n cams and I apply anti sieze lubricant to them and the adjuster bolt so they dont sieze the next time.
The heating and vibrating hammer blows works well for me, maybe others have different tricks up their sleeve as theres more n one way to skin a cat lol.
Good Luck n God Bless, let us know
John T [email protected]
Greg F
02-20-2004 17:20:54
 Re: Re: Brake disassembly in reply to John T, 02-19-2004 14:45:55
Thanks for the tips. I am going to work more on it this weekend. Wish me luck.
Greg
