3020 Run Problems
Ron Joubert
03-23-2005 13:29:03
Have a 3020(gas,early model) that I inherited from my son that passed away. Did extensive refurb and replaced numerous parts last year, including all ignition components and installed a rebuilt carb (Marvel Schebler). Tractor ran fine all summer, but at end of summer developed a severe miss. After much troubleshooting and finally pulling the head I discovered a badly burned exhaust valve in #4 Cylinder. Repaced valve, had others refaced and reinstalled head. All new gaskets, torqued head bolts and adjusted valves by the book. Had tough time starting tractor and when finally did, RPM ran up over 2000 with throttle fully closed (High/low stop on throttle lever was previously removed.) Tried everything to lower RPM, including disconnecting governor linkage and closing throttle valve by hand-----nothing worked. Pulled the carb and dissembled and found no trash or other obvious problems. Reinstalled carb and had same problem. At a loss to figure it out! Could the accelerator section of the carb be malfuncioning? Any help I can get would be greatly appreciated with thanks!
donmyeil
03-24-2005 13:48:53
 Re: 3020 Run Problems in reply to Ron Joubert, 03-23-2005 13:29:03
Sounds like the governer linkage is suck at the pivot area of the governer. Just penetrate it and work it. This is the rod to the carb. Hope this helps Don
Ron Joubert
03-24-2005 07:32:18
WTW (Dave) Your analysis makes a lot of sense. Have not had an oppotunity to check manifold gaskets, but remember that I had a tough time aligning the gaskets and installing the manifold by myself. Probably be a few days before I can check, but will let you know what i find.
msb
03-23-2005 17:26:00
Thats wierd! Pull the cover plate off the carburetor and check the accelerator pump diaphram.It is on the plate.After reassembling the daiphram see if the diaphram will hold a vacuum.There is a hole on the rim of the plate where it gets its vacuum from.Trace the passage down while you have it apart.Suck on it with your mouth and put your tongue on the hole to see if it is good and holds vacuum.A lot of the time the tractor would backfire and blow the diaphram.That was the worst fault of those Marvel Schebler carburetors.
PJBROWN
03-23-2005 15:43:14
I have never worked on a 3020 before but I have worked on my share of other gas engines. It almost sounds like you have a vacum leak or some how air is leaking in. What's the engine temp ??
WTW
03-23-2005 14:49:15
Ron, From what you have said here I would suspect that you have an intake manifold gasket out of place causing the engine to pull air in from another source other than the carburetor. This would be the reason for the hard starting and the over revving with the carburetor at an idle position. Check and see what you find and post back if that is not your problem Good Luck, Dave W.
