50 concerns
Bill46
03-23-2005 09:22:15
Just got a 50. I think it's a 52 model by the serial number. Anyway, when cold this sucker floods real easy. Very little or no choke at all. Also, the pump pulls the rockshaft right up, but even with a large wrench on the ends it goes down real slow. There is no lift linkage on it yet...is this normal for a 50 or should the square ends go down real easy? This is my first old green machine and I want to get things right. I hate to tear the carb apart because once started...the old girl runs great.
I already have new rims and tires ordered for her...she is a keeper.
buickanddeere
03-23-2005 11:15:30
 Re: 50 concerns in reply to Bill46, 03-23-2005 09:22:15
Could be as simple as some joker cranking the idel screws about 4 turns opens so it will idle extra slow. Try 3/4 turn. On occassion a carb with all-fuel jets will get swapped onto a gasser. or from a 70 down to a 60. The 50's carb has smaller bores internally however. Check the aircleaner, it could be bunged tight.
Bill46
03-23-2005 11:28:03
 Re: 50 concerns in reply to buickanddeere, 03-23-2005 11:15:30
Thanks...the air cleaner is fine, I already cleaned and painted it. My goal is to make the tractor like new. It will take me awhile...but everyone has to have a toy.
Bill46
03-23-2005 10:12:25
Thanks, and yes, I have both an operator and repair manual on order.
Mike M
03-23-2005 09:44:37
I can't say about your flooding problem ? It may not be a problem ? Every tractor starts different. On that rockshaft there is an adjustment for the rate of drop depending on how heavy of implements you are using. That adjustment is on the back of the hyd. housing in the lower center of it. You should find a cap nut with a jamb nut behind it. Take off the cap and you should be able to loosen the jamb nut and run the threaded part in and out with a screwdriver. I think in is faster ?Not sure though. Get in touch with JD and get some manuals ordered.
F-I-T
03-23-2005 09:44:00
>>>...the pump pulls the rockshaft right up, but even with a large wrench on the ends it goes down real slow. There is no lift linkage on it yet...is this normal for a 50 or should the square ends go down real easy?
The arms are gravity down, and if the throttle valve is partially closed, which controls the speed of drop, they could go down fairly slow using only your weight on a 1 foot long wrench.
A 500# plow at the ends of 801 hitch arms (for a moment of maybe 3 feet) would make a difference on the speed of drop as well. You can try a long pipe on your wrench, or look in the manual and adjust the drop valve to full open.
You might look at your float level, but I'll leave the carb problem to the carb experts.
Fran k
JD hauler
03-23-2005 19:20:04
 Re: 50 concerns in reply to F-I-T, 03-23-2005 09:44:00
any chance your rubber seal on that automatic sediment bowl not shutting the gas off the whole way, bet 10 bucks it is if you havent replaced it, and the diaphrams also.
