3020 lights wont work
mgb
03-23-2005 09:10:37
I recently bought a 1967 3020 gas. It's 12 volt of course. It doesn't have fenders. The lights are mounted, one on each side, on the pipe bracket like all JD's of that era. I don't have any fire in the wires going to the lights. But I can run a direct wire from a hot wire to the single screw on back of the light and it will light up. Here's the problem. I hooked up one light and was letting it burn while I hooked up the other one. The first one went out after about 2 minutes and now refuses to burn. I checked the wire and have 12 volts going to the light. Is that to much? Is the voltage to each light reduced when it's working thru the original switch? Or did the light just burn out because of age. They both appear to be the original sealed beams that came on the tractor from birth.
Garland(Gman)
03-23-2005 16:50:01
 Re: 3020 lights wont work in reply to mgb, 03-23-2005 09:10:37
MGB I just put a set of fenders on a 4000 and getting a good ground is the secret,I put new wiring harness on from mother Deere(fender)but I about lost my patience fooling with the darn thing. Gman
