2010 rear hydraulics not working.
Ray Johnson
03-23-2005 07:55:28
Have a 2010 and just got back from the John Deere dealer with new hydraulic hoses for use with a woodsplitter attachment. The salesman said that the hose connectors would stay in place when the engine was started. He said the ball bearings on the tractor female connectors would push in and grab the male fittings on the hoses. The fittings slide in fine, they just don't grab and lock in.
On the top tractor hyd fitting, I'm assuming it's the pressure side since there is always slight leakage of fluid.
Is there a switch or a lever or something that will make the hydraulic pressure flow back there and do something?
On the dash on the far left side I know the lever is supposed to have something to do with the hydraulics, but no matter which way I push it, nothing happens except for a whining sound and a drain on the engine.
Any experts out there with any suggestions? The Deere dealership hasn't been much help.
billde
03-23-2005 08:13:14
 Re: 2010 rear hydraulics not working. in reply to Ray Johnson, 03-23-2005 07:55:28
Ray, there is a lever[rod] to the side of your female coupler, push the hose in and lock with the lever. This locks the coupler and opens the valve to allow fluid to flow. I have a 2010 if you have further problems post back. Don't expect much help from dealers on 1010 2010, mechanics hate them and with good reason.
billde
03-23-2005 16:43:37
 Re: 2010 rear hydraulics not working. in reply to billde, 03-23-2005 08:13:14
Ray, just checked, on my 2010 the lever has to be in line to function. Push hose coupler in hard, you will feel it seat, to remove give the hose a sharp tug. If the coupler moves to the rear, but won't release, rotate the lever to 90deg, straight up or straight down. Return lever to straight back once you're free. Hope I haven't confused you.
Ray Johnson
03-23-2005 17:27:43
 Re: 2010 rear hydraulics not working. in reply to billde, 03-23-2005 16:43:37
The two levers for the female coupler do not move but just a hair. In between the levers there is a plate that is bolted on that is restricting the movement of the levers. Maybe that should come off?
Also, there is some kind of valve up under the dash cowl that is supposed to have something to do with the rear hydraulics. When I move the far left dash lever... it leaks like a rusty bucket up under the dash! Got mad... didn"t look very closely after that to see exactly where the leak is.
I"ll try again tomorrow.
If you know anything about the plate that is restricting the female coupler movement... let me know.
billde
03-23-2005 18:02:29
 Re: 2010 rear hydraulics not working. in reply to Ray Johnson, 03-23-2005 17:27:43
Ray just found out there are two types of couplers. I may have given you the wrong instructions. What is the serial number of your tractor? are the levers on the side or top and bottom? Email me off the board.
Ray Johnson
03-24-2005 17:27:14
 Re: 2010 rear hydraulics not working. in reply to billde, 03-23-2005 18:02:29
I don't know your email address, so send it to me in an email.
The levers, as you are facing the rear of the tractor, are on the left hand side of the unit that houses the female hyd connectors.
As for the serial number.... there are tons of numbers all over the tractor. I've been wondering which number is the main number. If you can tell me where to look, I'll let you know.
billde
03-24-2005 18:17:47
 Re: 2010 rear hydraulics not working. in reply to Ray Johnson, 03-24-2005 17:27:14
Ray, [email protected]
