36 jdb anybody
xragman
03-23-2005 07:01:31
anybody know the installed height of valve springs & seat pressure ? when I asked my deere counter man, he got that deed in headlite look.
Duane Larson
03-23-2005 16:40:18
 Re: 36 jdb anybody in reply to xragman, 03-23-2005 07:01:31
xragman,
The only valve spring specification given in the FSBs for your B is the spring compression pressure - it should take 28-34 lbs to compress the spring to 2 13/16".
xragman
03-24-2005 06:49:07
 Re: 36 jdb anybody in reply to Duane Larson, 03-23-2005 16:40:18
THANKS duane & others. just what I wanted to know. deere counter man said I could order new ones for $10.00 bucks a head, no refund. man them big long pushrods are heavy for such lite springs. ( been working on cars tooo long )
Maark
03-23-2005 12:13:17
Any old Deere that I work on, I always install a machine washer under the spring. It really helps those old tractors idle much better as the pistons have a habit of sucking tne valves open and causing an erractic idle. Those machine washers can be found at a hardware store that has all those plastic boxes with hard to find nuts and bolts.
Mike M
03-23-2005 09:56:19
Maybe Duane Larson will chime in as he has copies of all the service bulletins. JD wasn't big on specs. on those old tractors. I think you may be able to get at least spring pressure specs. for a later B and at least test your pressures,but that unstyled may use different springs. Good news is that on these old slow RPM engines that stuff isn't very critical.
