Hard Startiing JD H with AC C88L plugs
JDHDon
03-22-2005 17:20:01
Spring is finally around the corner (it was up to 40 yesterday) and I wanted to get my "44 H started. I put new AC C88L plugs in it and it would not start...I cranked on the flywheel for 30-40 minutes. Then I changed the plugs to Champion D21"s and it started with two pulls. The carburetor is freshly rebuilt. I"d appreciate any insight on why it is so hard to start with the C88L"s and easy with the D21"s
rmiller
03-23-2005 15:22:27
 Re: Hard Startiing JD H with AC C88L plugs in reply to JDHDon, 03-22-2005 17:20:01
Had AC's in my 43 B and had the same problem.Sometimes it would start pretty good and sometimes it would not start at all.I thought I might have had a mag problem.Changed to champion D21's.End of problem.
mattd
03-22-2005 18:01:43
your ac plugs were probably fouled with invisible gas deposits(flooded). and when you put in new dry plugs that werent fouled it started right up. i dont know which is the hotter plug of the two but if you found out, run the hotter and that would help
matt
mattd
03-22-2005 17:33:42
matt
John51
03-23-2005 02:41:41
 Re: Hard Startiing JD H with AC C88L plugs in reply to mattd, 03-22-2005 17:33:42
They are both "hot" plugs so it shouldn't matter. However, I ran C88L in my tractors for years but about 5 years ago I started having problems and switched to Autolite 388 and it really helped.
