Dexter, the same set of points and condensor and coil fires BOTH cylinders, so if one sides weaker, the problem might be a plug wire or an individual spark plug or else theres a problem or difference concerning the cap or rotor. At idle, its normal for the left side to fire stronger than the right you know, could it be thats what youre referring to as one weak side or running on just one????? ?? If you remove the plugs but have them wired with their sides grounded and you crank her over, insure BOTH make a good visible blue spark and are about the same, are they??? If not, try swapping wires and plugs to see if you can isolate a bad plug or a plug wire???? If its always just one side thats weak regardless (i.e. one cap tower) remove the cap and check for cracks or carbon traces and problems or differences in the caps internal pickup terminals. Other causes of one side weaker could be a worn bearing/bushing or cam lobe so check the points gap on both lobes and try running the points gap a tad wider than the 0.015 spec n see what happens????? ?? To set the initial static start timing, loosen the mags top n bototm mount bolts and rotate it CW forward to retard or CCW backwards to advance. To time it set it so she just snaps to fire the left cylinder right as the Flywheels Left Hand Impulse (LHI) Timing Mark passes by the flat mark on the tractors side located at the 3 o clock position. If too soon before, its too fast and the flywheel may kick back but if too late she may be harder to start. You could first rough her in by setting the mag to max retard forward CW,,,,, ,,,,then slowly rotate the flywheel and stop when the Flywheels LHI is at the 3 o clock flat mark,,,,, ,,,,then slowwwww wwlyyyyy yyy advance the mag by rotating it rearwards CCW till she snaps,,,,, ,then fine tune it by turning the flywheel and listening for the snap and set it so it snaps just as LHI passes 3 o clock flat mark. SUMMARY Make sure both sides produce an equal good blue spark,,,,, ,make sure the plugs are good (replace if burned or fouled or heavy blackened),,,,, ,,insure both wires are good and theres no cracks or carbon traces in the cap,,,,, ,insure the points are gapped to 0.015 and NOT burned or pitted or gray oxide coated (replace if bad),,,,, ,,,,set the initial start timing per the above,,,,, ,see what happens. The rear coupler area is where you loosen those 4 screws to set the lag angle which determines where she fires at advanced which is over 250 RPM and the wind n trip is de activated, but set the start timing as above n see how she does. It takes a timing light to insure where shes running at over 250 RPM and depending on the coupler you have and the wear in the drive cup etc a good starting point is to set the index mark about 2 1/2 marks to the left of straight up and go from there, then use a timing light to see where shes really firing at. John T Nordhoff
