4010 Hyd pump leak
Ray
02-19-2004 09:38:40
I've had a leak on one of my 4010's. Thought i just needed to put a kit in the pump but when looking at it the oil is coming from one of the caps on the side of the pump. The cap takes a 1/2" drive extension and its tight. Is there an o-ring or something on the cap that can be replaced to stop this leak? thanks
G-MAN
02-19-2004 11:01:51
 Re: 4010 Hyd pump leak in reply to Ray, 02-19-2004 09:38:40
Yes, it should have an o-ring sealing it, and that should take care of the leak. I don't think there are any pipe-threads on those pumps. If it would happen to be one of the piston bore plugs, it would take an o-ring and also a plastic washer that protects the o-ring from being cut during plug installation. Should be an easy fix for you.
