Crankcase vent on 720D with pony motor
Freddy
03-21-2005 15:41:24
I have pulled the reduction cover and the right brake for some bearing work on the 720D. What I found was the gasket was puhed out into the case in the inside where the engine oil fill was causing a leak into the reduction drive. Also the right brake house had the gasket squeased out between the bolts and was leaking. Checked the left same way. Did the prevous owner have a crankcase pressure problem that it pushed these gaskets out? Where is the crankcase breather on a pony start tractor?
720Deere
03-21-2005 18:58:33
 Re: Crankcase vent on 720D with pony motor in reply to Freddy, 03-21-2005 15:41:24
The diesel definitely vents through the pony motor. It vents through the oil drain passage on the pony up through the pony motor and into the pony motor air cleaner. The electric start diesels had a breather sort of like that on an A that sat over the pony drain hole.
freddy
03-21-2005 19:25:42
 Re: Crankcase vent on 720D with pony motor in reply to 720Deere, 03-21-2005 18:58:33
thanks all for the info
Mike M
03-21-2005 16:37:39
I have found it a normal condition on these old tractors to have bad gaskets. If I remember correctly that pony motor has a passage up through it's front cover and then maybe a tube going from somewhere hooked to the side of the pony air cleaner for the diesel engine vent.
freddy
03-21-2005 18:33:22
 Re: Crankcase vent on 720D with pony motor in reply to Mike M, 03-21-2005 16:37:39
The really strange part is the gaskets were not broke. just pushed out in one spot till they leaked. stretched out looking.
