3 pt semi mount plow
T Pollack
03-21-2005 09:48:54
I recently purchased a 3-16 semi mounted plow. I think its a 145?? How can I be sure? Where is the identification tag located on the plow? Is there a difference between a F145 and a 145? And what is the difference between a F145 and a F145A? I also see there is a F1450 and 1450; what is different with these models?
Thanks
BillNNY
03-22-2005 05:40:13
 Re: 3 pt semi mount plow in reply to T Pollack, 03-21-2005 09:48:54
I can answer a couple of the questions. One way to determine the difference between a F145H and a F145A is the "H" series uses 4 bolts to attach the trip to the beam, while the "A" series uses 3 bolts. The serial tag should be in the front of the plow. We have several in our "storage area" and I have not looked, but believe the tag is on the main post casting. On some other plows,, the tag is on the main beam. I can check and post back.
Hope this helps
Bill
John e.c.MI
03-21-2005 17:41:44
I had a 1450 a long time ago. The big difference is the amount of clearence between the two.
