720D Stopped Running
Tsmith1499
03-20-2005 21:06:19
I went and looked at a 720 Deisel today that has been sitting for about a year. It started right up but after running it around for about a 1/2 hour it slowly shut down like it ran out of fuel. It had plenty of fuel in the tank though. Could the 2 fuel filters be clogged? I know on some of the "newer" JD tractors if the filter clogs up it will just stop running. Thanks Tom
F-I-T
03-21-2005 14:56:55
 Re: 720D Stopped Running in reply to Tsmith1499, 03-20-2005 21:06:19
I disagree about not changing the second filter. After sitting for a year (or more if the owner's memory is fading) there could be any kind of degradation in the filter element and the fuel within. Change them both, but while they're out, blow some compressed air backwards through the rack from the bleed port on the left side. You might be surprised that some slime might not come out.
Then flush it by letting filtered fuel run through it. Drain this into a clean (I like white) container until you see no more trash. Not even a speck.
Also, check the tank vent line. They can clog and impede fuel flow, especially if the transfer pump has a broken drive lug. If so, time for a new governor shaft.
Be sure to check the flow of fuel from the sediment bowl through the line to the output at the 1st filter housing. There is a small filter in the top of the sediment bowl that can foul. Look for a brownish varnish that coats the screen and slows the flow.
Frank
720Deere
03-21-2005 14:31:15
You could have algae in the fuel or some other contaminent that has clogged the primary filter. As buickanddeere stated, don't change the secondary filter (the outlet side) unless absolutely necessary. If you do change the secondary, I would take the discharge line loose and flush it good after the new filter is installed just to be sure that you didn't let something loose into the fuel system during the change.
Does the engine spin over easily with the compression release depressed? If it shut down slowly, it almost sounds like something wasn't getting oil and started to tighten up on you.
Mike M
03-21-2005 06:13:44
Double check that the fuel shut off on the bowl is ON. Then pull out the bleeder screws on top of the filter housing and check for good flow. If nothing comes out take the line loose that feeds the filters,if good flow there then change your filters.If nothing there then work your way back to the tank.
buickanddeere
03-20-2005 23:18:37
Just change the 1st filter. The 2nd should never get dirty. If the 2nd filter is changed, any mistake will put dirt into the injectors. Is the fuel full of slime, water and algae?
tsmith1499
03-21-2005 15:07:27
 Re: 720D Stopped Running in reply to buickanddeere, 03-20-2005 23:18:37
Thanks for the input. I didn't check the fuel to see what it looked like. When the guy bought it a year ago, he ran it around a little then put it into one of those 40' long storage containers that are watertight. He did fill the tank with fuel before he put it away so it would not attract as much moisture. As far as I know this is the 1st time it has been started in over a year. Everything sounded & ran good until we were standing there talking and it shut down. It shut down just like when you turn the fuel off on a gas 2 cyl. Other than that it ran flawlessly. Unfortunately the tractor is about an hour away and is kinda hard to get access to. Scheduling thing. I am hoping to go back this or next weekend and try and get it running again. On the filters, I assume (bad thing to do)the primary filter is the first one in line from the tank and the secondary is the next one. This is my first deisel so it's gonna be a learning experience!! Thanks again, Tom
