630 PTO turns when cold
Harley in PA
03-20-2005 15:14:22
Hi,
The 630 has a slight problem. When the PTO is in gear and the tractor is cold, the shaft turns without the clutch engaged. I had been using it to mow with, and it didn't really bother me too much. But I spread some manure with it a couple of months ago, and I kind made a mess.
I had to take it out of gear, and then stop the tractor when I wanted to spread. It took six or seven rounds before it stopped dragging. This only started in the last year as it didn't do it last year.
Any suggestions?
Also, it has a three point hitch on it. I've heard that I have to take the elephant ears offf to service the PTO. Is this true?
Thanks for any help.
Harley
Harley in PA
03-21-2005 17:32:04
 Re: 630 PTO turns when cold in reply to Harley in PA, 03-20-2005 15:14:22
Hello again.
I changed the oil today. The oil that came out of it was black like tar but it didn't seem to be too much thicker than the 30 wt I put in it. It had at least two extra quarts in it.
When the oil was out, I turned it over for a second, to try and spin some of that oil off. While the oil was out, it behaved nicely. However, when I put in three new quarts of oil, it did the same thing.
I didn't know it had a brake. Where is that?
Thanks for the help.
buickanddeere
03-22-2005 01:21:24
 Re: 630 PTO turns when cold in reply to Harley in PA, 03-21-2005 17:32:04
Use hydraulic/trans fluid such as Hy-Guard made for wet clutches. Sounds like that brake is worn out or out of adjustment.
fixerupper
03-21-2005 11:27:23
If it still doesn't stop for you with the proper oil in it and the brake set up properly, you could have warped clutch disks. If it has ever been used to unslug a grinder-mixer or silage chopper without a thorough clean-out first, the clutches will be blue and probably warped.
mfs
03-21-2005 05:30:19
The manual for my 620, which should be the same as a 630, calls for 10 weight oil.
Chuck Westerfield
03-21-2005 04:13:27
Per the other post, heavy oil from rear end is a possibility. I've changed this on one tractor and as I recall you have to pull the rear unit. I would try changing oil first and adjust brake.
buickanddeere
03-20-2005 23:22:11
Cold thick oil with too tight a pto clutch and a too loose pto brake.
HillBilly in Vegas
03-20-2005 18:09:59
As the previous posts said, it sounds like adjusting the PTO brake will solve the problem. Changing the PTO oil is a good idea, but I would check the adjustment of the PTO clutch as well. If the clutch needs adjusting, you"re committed to changing the oil anyway. You do have to take off the right side elephant ear (and 3pt) to adjust the clutch.
Chuck Westerfield
03-20-2005 15:42:05
I would change fluid before anything else and adjust the brake. The unit uses 30weight oil and sometime people put in the heavier stuff. Doesn't sound like much of a problem....check your manual for adjusting the brake.
RLA
03-20-2005 16:04:55
 Re: 630 PTO turns when cold in reply to Chuck Westerfield, 03-20-2005 15:42:05
By all means drain & install new oil. If this condition returns there's a good chance you have a seal leaking where power shaft couples to transmission. 80w90 weight oil entering the pto housing will cause this & you'll know if the pto oil level is way over full.. Check & messure drained oil.. RLA
