Clutch Plate Gear Removal
Green '52'
03-20-2005 14:34:13
I am trying to get the gear off, had a puller on it, also used heat. Am I missing something here and does just the gear come off or the whole clutch plate? Also have two threaded holes in the clutch plate, do I use those to push the plate and gear off?
Any help would be appreciate, I am really stuck on this.
Thanks
Mike M
03-21-2005 07:17:31
 Re: Clutch Plate Gear Removal in reply to Green '52', 03-20-2005 14:34:13
That clutch driver is all one piece held onto the crankshaft with tapered splines. Take the bolt and washer out in the center and make sure you can read the V timing marks if not put your own marks on it so it goes back on in balance. Screw the bolt back in loose to put a puller against and use those two holes for the puller. I don't think that you will have much luck using them as a pusher on that model as it is very thick and would require bolts with lots of threads I can't even remember if the holes even go all the way through. I use a homemade puller made from a piece of heavy flat bar stock with holes in it for the 2 bolts then just draw it up against the center bolt. Get pressure on it and then give it a whack. This should pop it loose.
Ben.So.Tex
03-21-2005 06:30:48
I have used the two method and it works good, Just did two Gs yesterday with no problem. You have to use the square nuts so they will hold in the slots, thighten them up an then put a board on the crankshaft and wack it with a hammer, Do not bare down on the bolts to hard you don,t want to break the cast. Good luck ben
F-I-T
03-20-2005 16:31:32
Can you be more descriptive? What tractor model are you talking about? Is it the clutch driving disk you are speaking of?
If, it is a flat driver with two holes, yes you can thread two bolts in there which will help push the disk of of the crankshaft. The gear and disk are one piece.
Frank
Green '52'
03-20-2005 18:10:53
 Re: Clutch Plate Gear Removal in reply to F-I-T, 03-20-2005 16:31:32
The tractor is a 1952 John Deere B and yes it is the clutch driving disk.
You say they are both together, heating the gear won't help much? A little liquid wrench together with heat????
Thanks again F-I-T
F-I-T
03-20-2005 19:38:02
 Re: Clutch Plate Gear Removal in reply to Green '52', 03-20-2005 18:10:53
third party image
Okay, here's a picture of what I think it is you have. I've always had good luck using the pusher bolts to give a good pressure to the disk. Then you can try some penetrant, but I believe heat will ultimately allow it to release.
I've never had much luck with a gear puller on those.
Frank
Green '52' Attn: F-I-T
03-21-2005 16:38:30
 Re: Clutch Plate Gear Removal in reply to F-I-T, 03-20-2005 19:38:02
Thank you for your input. The bolts thru the clutch plate worked out great. A little heat on the plate itself popped it right off.
Again thanks to all you guys for your help.
