Right side main bearing has SLACK on crank. G
Ben.So.Tex
03-20-2005 11:38:00
I am working on the clutch on my G and have the pulley off, I can move the the crank up and down and notice some play in the bearing... Can I tighten up on the bolts with the slotted nuts and remove the slack? Are their any shims between the bearing clamps? Thanks Ben..
Green B
03-20-2005 13:50:30
 Re: Right side main bearing has SLACK on crank. G in reply to Ben.So.Tex, 03-20-2005 11:38:00
Should be shims used to set clearance.
