Carbon in the sparkplug hole
Ben.So.Tex
03-20-2005 04:24:42
The plug hole on my G is caked with Hard carbon,only has a hole about 1/4 inch for it to fire through. Can I chip the carbon back into the cylinder and not have anything to worry about? I do have a plug tread chaser that I could run in their and that might break it loose. Thanks Ben
Tony W
03-21-2005 05:48:30
 Re: Carbon in the sparkplug hole in reply to Ben.So.Tex, 03-20-2005 04:24:42
One thing that I have done and it worked well was to spray some oven cleaner down the plug hole and allow it to soften up the carbon. Then start up warm up and pull it hard while wearing a cap.
Best of luck.
Gerry_Luzerne_MI
03-20-2005 14:01:49
Also might want to add some grease to the flutes of the tap. The pieces will stick to the grease. I have done this over the years. You may not get them all, But you will get some.....
Maark
03-20-2005 07:20:03
Remove the aircleaner elbow and dribble some water through the carb when it is running. The steam produced in the combustion chamber will clean a large portion or maybe all of the carbon out.
Hoosier JD
03-20-2005 08:23:13
 Re: Carbon in the sparkplug hole in reply to Maark, 03-20-2005 07:20:03
I agree with Maark. An "experienced" (old) mechanic taught me that trick. I used to do that as the first and last step in a tune-up on the old engines when I was younger (don't know about todays vehicles). I would have the engine warmed-up and idling, then dribble some water into the carburetor, you wouldn't believe what would come out of the exhaust pipe! No promises, helped me though. Good luck. Mike
Dave in SV
03-20-2005 15:38:54
 Re: Carbon in the sparkplug hole in reply to Hoosier JD, 03-20-2005 08:23:13
Is this process only remove loose carbon, or will it dislodge carbon build-up in the combustion chamber?
Mike M
03-20-2005 05:53:07
I don't know if it would help ,but you may try a vacume cleaner next to the hole as you chip it off. Maybe some would get sucked out instead of falling in ?
