B Crank specifications
Green B
03-19-2005 20:15:21
Can someone give me crank specs for a unstyled B in the 5000 series.Also how much can crank be below this befor you need to go to undersized berrings? Can someone tell me where to get connecting rods redone? Thanks Chris
Duane Larson
03-19-2005 21:34:29
 Re: B Crank specifications in reply to Green B, 03-19-2005 20:15:21
Chris,
Crank specs are as follows:
Crank at pulley bushing 1.747-2
connecting rod bearing 2.503-1
crank at connecting rod bearing2.500-1 main bearing ID 2.254-2
crank at main bearing 2.250-2
where all measurements are in inches, and -2 means crank wear of 0.002" undersize is acceptable, rod bearing wear of 0.001" is acceptable, etc.
Green B
03-20-2005 07:35:46
 Re: B Crank specifications in reply to Duane Larson, 03-19-2005 21:34:29
Duane thank you for the information.
