66 Plow Truss Rod and Trailing Wheel Adjustment
J Herp
03-19-2005 14:59:52
I have a 66 hydraulic plow. Does the plow set down in the notch at the top of the casting of the trailing wheel? What is the proper adjustment of the truss rod, the long rod with the springs on it? To me, it looks like the notched casting should be able to pivot. If the plow sets in the notch, I don't think this would be possible. Any information would be appreciated.
Mike Aylward
03-19-2005 16:24:23
 Re: 66 Plow Truss Rod and Trailing Wheel Adjustmen in reply to J Herp, 03-19-2005 14:59:52
J Herp, the tail wheel rests in this casting when the plow is in the ground, locking the wheel solid. When the plow is lifted the rear wheel is freed to pivot. If this wheel was allowed to pivot at all times the plow would not plow straight, nor would it plow level due to the varying pressure the wheel would be carrying (yes, this wheel carries weight when plowing). Hope this helps. Mike
J Herp
03-20-2005 13:06:09
 Re: 66 Plow Truss Rod and Trailing Wheel Adjustmen in reply to Mike Aylward, 03-19-2005 16:24:23
Mike, Thanks for the info. This is what I needed to know. J
