Advantages of LP Tractors
Tye
10-24-2003 16:52:53
Why did John Deere make LP tractors? What are the advantages and disadvantages? Thanks
OK-AL
10-24-2003 18:32:35
 Re: Advantages of LP Tractors in reply to Tye, 10-24-2003 16:52:53
Propane used to be less than 10 cents per gallon. This was obviously a long time ago, but it beat paying 25 to 35 cents a gallon for gasoline. Just like the other posts say, engines run much cleaner than gas or diesel. I have to change the oil in my 720LP by the calendar, instead of looking at it because it never gets dirty or brown. It always looks like I just poured it in, regardless of how many hours are on the engine since the last oil change.
Disadvantages include propane companies not wanting to come out to your place to only fill a 30 or 40 gallon tank, the possiblity of leaks, and the general danger of having a tank of compressed gas right over an engine.
BUT, it always starts - regardless of the outside temperature. As a matter of fact, i've never had to do anything to the engine since i've owned it. That includes spark plugs. They look like new too.
OK-AL
G-MAN
10-24-2003 17:09:53
Deere made LP tractors because there were areas of the country where LPG was cheap and very readily available, like in the south. It is also higher octane than gasoline, and will withstand more compression, although the extra benefits of that are offset by the fact that gasoline has more BTUs per gallon. LP is a little more of a hassle to handle and refuel with, and it's kind of hard to carry five gallos to the field if you run out of fuel, unlike gasoline. It's also heavier than air, and will pool near the floor of enclosed buildings if the tractor inside has a leak, and it doesn't take much of a spark to set it off if the mixture is right, so it's important to make sure the fuel system is up to par and leak-free. A lot of shops won't even let an LP tractor sit inside over night, for insurance and safety reasons.
RayP(MI)
10-24-2003 17:35:29
 Re: Re: Advantages of LP Tractors in reply to G-MAN, 10-24-2003 17:09:53
Well, if you can get past those funny round tanks jutting out of the usual sleek streamlined hood... The LP gas tractors were far cleaner burning, meaning extended engine life, and extended time between oil changes. If you ran out of fuel, you could carry a small tank out to the field, and hook it up, although this was a bit of a pain.
moline
10-24-2003 19:47:19
 Re: Re: Re: Advantages of LP Tractors in reply to RayP(MI), 10-24-2003 17:35:29
My 60 was setting outside for years when I rescued it.The engine was stuck,clutch discs had fallen apart,radiator bad,throttle lever seized up at the friction disc,radiator bad,water pump bad,drawbar was egg shaped,tires and rims shot.After repairing all these things,I shot some propane in the tank.It fired right up and the fuel system worked great!I have gas tractors that cant set all winter without stabil and storage fogging oil and draining the carb or they wont run.It has been my experience that propane systems are cleaner and have less maintenance.I have been to shows and I almost never see a gasoline tractor leaking fuel all over a nice paint job and dripping on the ground.Yet I find a lot of propane tractors hissing and leaking fuel.I guess if you cant see it dont worry about it.Problems like that give propane a bad name and cause problems like the previous post mentioned about burning buildings down.Sorry to ramble on,but I really like those old bottlegas tractors.Moline
