2520 gas won't start
tficklin
03-18-2005 21:48:28
I rebuilt my 2520 and got it running and reset the timing and the whole bit. Now, I can't get it to fire. It ran great for about 2 hours while I checked for leaks and such. I then shut it off and buttoned up the hood and side shields and then went to restart it and it just won't fire. Every once in a while it will hit once or twice.I went through and checked my points, condenser, coil and carb intial adjustments. It is getting plenty of fuel and has good spark. After I crank on it, the plugs are wet. Even went back and done a compression test to see if I messed something up there, and they came back at 140-145 psi. The tech manual talks about a restistor wire, and as far as I can tell it is fine also. Got any suggestions? I'm just at a loss.
Hoosier JD
03-19-2005 20:06:46
 Re: 2520 gas won't start in reply to tficklin, 03-18-2005 21:48:28
What everyone told me was Autolite plugs. I put a set of 388 Autolite and electronic ignition in my 4010...helped immensely! Also had solid core Accel plug wires and a Zenith carburetor. Good luck, Mike
MSM
03-19-2005 04:19:16
Champion plugs?
tficklin
03-19-2005 06:38:11
 Re: 2520 gas won't start in reply to MSM, 03-19-2005 04:19:16
yes, RN11YC4 to be exact.
Mike M
03-19-2005 09:08:02
 Re: 2520 gas won't start in reply to tficklin, 03-19-2005 06:38:11
Once plugs get wet (especially champions) they are mostly junk nowadays. Try a new set of autolites.
Mike M
03-19-2005 09:08:32
tficklin
03-19-2005 09:29:48
 Re: 2520 gas won't start in reply to Mike M, 03-19-2005 09:08:32
Thanks for the help!
tficklin
03-19-2005 20:11:53
 Re: 2520 gas won't start in reply to tficklin, 03-19-2005 09:29:48
I figured out the problem. The spark was a little weak and I did some more tests and found that the 2 ohm resistor that runs from the key switch to the R-terminal on the starter solenoid was fine. I found that the key switch was fried and the R-terminal on the starter solenoid was fried also. I replaced both and everthing fired right up and ran well. Thanks for your help though. I guess I should have dug a little deeper in the manual.
Mike M
03-19-2005 09:08:18
