227 Corn Picker
stevejd60
03-18-2005 20:27:53
I'm interested in getting a 227 picker for my 60. I've never worked with a picker before and probably won't use it much but have always wanted to have one. What is the value of a complete picker with all of the mounting hardware? Anything special to watch out for, if I find one?
Thanks for the help.
DGK
03-19-2005 07:13:30
 Re: 227 Corn Picker in reply to stevejd60, 03-18-2005 20:27:53
I have one on a 60 JD I used 3 yrs ago, but it looks somewhat rusty and have a #50 sheller on the back that is just like new. I think it is probably worth $400. Works real good but the picker needs paint. Look at the snappen rollers ,sprokets, chains, And if it is all bent up. It would be nise to look at one working on a tractor if I were looking. Hope this helps you. DOUG
Buckeye
03-19-2005 05:18:19
I have a good shed kept one I will sell for $300. 740-682-6717. Buckeye(In Ohio).
dcotton
03-19-2005 05:44:52
 Re: 227 Corn Picker in reply to Buckeye, 03-19-2005 05:18:19
What tractor was it last on? I am intrested in one for my 70 so it will need the universal mounts or mounts for a 70 gas.
Dennis
Buckeye
03-19-2005 09:33:49
 Re: 227 Corn Picker in reply to dcotton, 03-19-2005 05:44:52
It was on a late A. Would a 60 be the same mount? I have another one I use on a 60 every year. Works good.
dcotton
03-19-2005 15:17:04
 Re: 227 Corn Picker in reply to Buckeye, 03-19-2005 09:33:49
sorry unless its has the universal mounts it wont fit on a 70....Can you tell if its the universal or other? i could send you a picture of the mounts to help you figure it out..
Dennis
stevejd60
03-19-2005 09:37:31
I don't know if an A mount is the same as a 60. I would think it would be close. I have a manual for the picker and can't really tell much difference between an A and 60. Thanks.
stevejd60
03-19-2005 09:27:05
This one was on a 60. I haven't seen it yet, but intend to. Thanks to all for your help.
Loren-MN
03-19-2005 08:22:20
Dennis
I'd look for a 237. Had a 227 on a 60, ok picker, but the 237 on a 730 was much better.
Bruddies pop
03-19-2005 11:08:05
 Re: 227 Corn Picker in reply to Loren-MN, 03-19-2005 08:22:20
I would like to echo the 237 statement. I haven't run one but I was told by my dad that the 237 was quite a bit better than the 227.
