Installing new brake linings on B
Greg
02-19-2004 05:51:17
Is there a specialty tool that is used to compress the rivets when installing new brake linings, if so can you discribe it or send a picture.
gary
02-20-2004 04:57:15
 Re: Installing new brake linings on B in reply to Greg, 02-19-2004 05:51:17
Greg,
I used a 5/16 transfer punch as Dan suggested. It worked great....I didn't have to buy the punch, we had one at work I borrowed. No other equipment was required, (except a hammer). It took about 5 minutes. (I still don't know what the legitimate use of a transfer punch is.)
Bguy-I got a Picture! Oop
02-19-2004 17:25:45
third party image
Here is my rivet setter. You place the object with the rivet in place between the "jaws" and turn the knurled knob down so it's holding the rivet snug. Then you squeeze the handles and it will set the rivet nice and tight. The fixture that fits on the small end of the rivet is made so that it will swage the thin walls as if they had been rolled back. The big end of the rivet fits against the opposing side. The tool is made to be bolted down but I have used it loose on a benchtop without any problem. This one works great, the white stuff you see is where I dunked it in phosphoric acid to kill the surface rust that was on it and I haven't got around to painting it yet.
02-19-2004 17:23:54
ChuckW
02-19-2004 09:51:52
I've tried a punch, but you will likely split the lining. I always take mine to the JD shop. Clean everything and have them ready...no problem. You have to work from the center out. I've always wondered if large steel rivets(used with a gun) would not work as good.
Dan
02-19-2004 09:00:42
Greg, The punch you are looking for is called a transfer punch. You can get a whole set from J.C. Whitney for $10. I think the size you need is a 5/16, its very easy to do. Use the search function here for more info, this topic is well traveled.
bent
02-19-2004 06:45:19
For what its worth, I looked for a riveter, then I asked the service guy at the local JD dealership and they did it in the shop with the proper tool for $10.
Bguy
02-19-2004 06:08:15
Greg, Most of them that I have done I used a punch to set the rivets and it worked quite well. A couple of months ago I saw a rivet setter on Ebay and I got it pretty cheap. It sets them a little tighter and neater looking than I could with a punch. I used it to put a new pad on my pully brake and it really looks sharp. I'll try to get a picture of it for you.
John-in-Ga
02-19-2004 10:10:23
 Re: Re: Installing new brake linings on B in reply to Bguy, 02-19-2004 06:08:15
Bguy, I would also like a picture of the rivet tool. I've unhid my email. Thank you.
JR
02-19-2004 08:57:04
I would also like to see pictures of your rivet setting tool. I have made a set that works fairly well, but always looking for better ideas. Feel free to email me.
JR
02-19-2004 12:28:57
 Re: Re: Re: Installing new brake linings on B in reply to JR, 02-19-2004 08:57:04
oops, i guess I need to unhide my e-mail address...
jdhbag
02-19-2004 06:13:46
Bguy I would also like a picture of the rivet tool. Thank you.
