1950 JD B Electrical System
elcajonfarms
03-18-2005 12:14:03
I just took delivery on an intact but unrestored 1950 JD B with electric start and an original 6 volt system. We were able to start it and drive it off the trailer and down the road about a quarter mile, then it stalled out just after turning into my property due to running out of gas. After fueling up, I ran the battery down trying to start (it was already pretty weak) then put a charger on overnight. This morning it cranked over fine but would not fire. There are two push/pull electrical switches on the dash (I don"t have a manual showing more than one, so I don"t know what they"re for). I pulled one out and the tractor almost fired, then the starter quit--stone dead. I pushed the button back but the starter won"t engage--totally dead getting no juice--so I assume that the old switch is defective and I broke continuity in a circuit somewhere. I"m guessing I can hotwire it around the switch, but would like to know if anyone has any other ideas. Also, where can I find a wiring diagram for this tractor??
John T
03-19-2005 06:05:34
 Re: 1950 JD B Electrical System in reply to elcajonfarms, 03-18-2005 12:14:03
Cajon, My guess would be one of the switches is lights and the other is ignition. The ignition switch may be to power up a Wico XB Distributor and if left on it could overheat the coil. If it has a mag instead of a distributor, the ignition switch could be a grounding kill switch. See what make or model is on the ignition and let me know?? My guess is its either a Wico XB Distributor or a Wico X Mag??
The earlier B's had a starter solenoid but the later ones (like your 1950) did not. Does yours start by pressing a floor foot pedal or is there an electrical push button that engages a solenoid on the starter???
You may have fried a Wico XB coil and you may just have a problem with the starter switch, regardless if its a solenoid or a mechanical type. Give her a good charge and try again and let me know what ignition and starter you have.
John T
elcajonfarms
03-19-2005 07:20:42
 Re: 1950 JD B Electrical System in reply to John T, 03-19-2005 06:05:34
The tractor has a round distributor Delco Remy No. 1111558 5K1. (It's raining here, so I haven't pulled the cover off to see what it looks like inside and I'm guessing it's a distributor from the exterior appearance). I don't see anything like it in my Model B JD parts catalog (No. PC-330). The coil is mounted directly on the distributor (my parts catalog doesn't show a coil either!). The second push-pull switch I mentioned in my original post is directly connected to the coil. I suspect the comments that I fried the coil are probably on target. I will be in Southern MN the next couple of days where they still have real John Deere dealers (unlike the yard tractor shops we have here in California). I wonder if they would still carry the coil in stock? And if so, what the part number is.
John T
03-19-2005 14:22:05
 Re: 1950 JD B Electrical System in reply to elcajonfarms, 03-19-2005 07:20:42
Yeppers, if that switch is wired to the coil, its the ON/OFF Ignition Switch and if left on it could have overheated the coil. It shouldnt be too hard to find a stock 6 volt coil at either Mother Deere or NAPA or Tractor Supply, Rural King, Central Tractor etc. If the coil shows an open circuit in its primary measured between its lil + and - terminals its bad, it should be around 1.25 to 1.6 ohms or so.
If you have a test lamp and turn the ignition switch on, there should be battery voltage on the coils input (from switch) side and over on its other output (to distributor) side, it should show zero volts when the points are closed (which they usually are) but near battery voltage when they are open if all is well inside the distributor that is and the points open n close and arent all burned or carboned up.
John T
elcajonfarms
03-19-2005 14:36:17
 Re: 1950 JD B Electrical System in reply to John T, 03-19-2005 14:22:05
Thanks for the suggestions--I will follow up. Another question though--when would you turn the button on? and off? Before cranking and after cranking, or just briefly on and off during cranking? The operating manual for a B that I have must have been published before JD included an ignition switch, since it makes no mention of one.
Jake
03-19-2005 22:40:24
 Re: 1950 JD B Electrical System in reply to elcajonfarms, 03-19-2005 14:36:17
That Delco battery ignition distributor was offered a few years later as a retrofit from the orignal magneto. It would have came with a switch that mounted in a hole you had to drill in the dash.
That distributor is not shown in any B parts book. You will find it in the model 60 and 70 parts book.
CLW
03-18-2005 13:08:52
Some of the B's had a key switch. Some did not. Don't know just why. The ones without a key were killed by pulling the throttle all the way back. Make sure yours is set 1/3 to 1/2 open to start. The lights worked on a push-pull switch so I would guess that is one of them. The second one may have been added as a kill switch or may have replaced the key. If you will send me your email address I will send you a wiring diagram of your tractor but it may be tomorrow before I can copy and send it for you.
CLW
Mike M
03-18-2005 12:32:09
It is possible that it has a battery ignition system and if that one switch was left on it could have fried the coil.
