4430 leak
charles
02-19-2004 04:45:17
A steady drip from the front pump ,but not from the shaft . the tractor is a Hydro FWA so less accessable from below , the tech manual just says remove radiators , coupler, and pipes and pull the pump . Looking at the archives on 4020 it seems that the whole front needs to be moved foward , is this not the case with the 4430 ?? and is removing the pump the only way forward? I cannot see the origin of the leak with things as they are Great tractor,a real beast! This tractor is rare in the UK Thanks in advance
charles
02-19-2004 06:58:57
 Re: 4430 leak in reply to charles, 02-19-2004 04:45:17
Thank you both for your responses , i can see a white plastic looking washer on the only cap I can actually see , If I understand you correctly Don I can remove the plates without moving the rad. In which case ,you may have saved me a lot of work ---great site--- by the way the service network for Deere is great , next day delivery of parts for a 20 year old tractor which is rare in the UK and the technician even offered to lend me his books on the history of JD I never got that from Massey F
david val
02-19-2004 12:41:16
 Re: Re: 4430 leak in reply to charles, 02-19-2004 06:58:57
after you remove the plates (no need to remove the radiator bolts, just loosen them), remove the foam seals and wash the area thoroughly (best with a pressure washer). there is a T on the right bottom side of the pump with 3/16 in. plastic lines attached to it. check these lines, they tend to get brittle over the years and brake. other common points of leak are the banjo fitting 'o' rings on the top of the pump, the seals between pump body and front cover and the 3/4 in. hoses around the pump. if it's really clean, you can start the engine and look for the origin of the leak. if the pump needs to be removed, as far as i remember, you need to loosen the clamping bolts of the pump drive, remove the hood and air filter assembly, slide out and tie out of the way the oil cooler/condenser, disconnect all lines to the pump, remove four bolts, rotate pump some and remove supply and pressure elbow fittings and remove the pump. prying may be required if splines are stuck in the drive. you can fabricate a T handle (i think from 9/16 nf bolt) and install instead of the plug on the top of the front cover. this pump is pretty heavy!.
a word of advice, if the pump is out of the tractor for leak repair, have it overhauled with a full seal kit and whatever else is required.
david
DON
02-19-2004 06:06:18
THE PUMP COMES OUT THE TOP. THE 4020 IS DIFFERENT, IT COMES OUT THE BOTTOM. REMOVE THE PLATES ON TOP OF THE PUMP ,OUT FROM UNDER THE RADIATOR AND YOU CAN SEE THE PUMP. IF YOU CANT SEE THE LEAK YOU WILL PROBABLY NEED TO REMOVE THE RADIATOR AND REMOVE THE PUMP. NOT AS DIFFICULT AS IT SOUNDS. DON
jdemaris
02-19-2004 05:33:53
Can't say I ever pulled the pump from a front-wheel-assist machine. Seems you ought to clean the pump and try to observe the leak; maybe you'll be lucky. The radial eight piston pumps were prone to leakage from any one of the eight piston caps. John Deere made efforts to remedy the situation by adding teflon sheaves to go over the piston cap o-rings. Some of the caps will be accessible with the pump in-place, and some will not.
