620 pto not turning
Greasy hands
03-17-2005 23:11:03
I have a 620 and the pto doesn't turn how big of a job is the to fix. Also what engine oil should I run in our 630. Thanks Greasy hands
John T
03-18-2005 05:47:21
 Re: 620 pto not turning in reply to Greasy hands, 03-17-2005 23:11:03
Greasy, not turning at all makes me wonder if you have it engaged via the shift/engage lever on the top right just to the right of the gear shift????? ? It needs to be engaged or else she will never turn. Its also possible that shifter has a broken pin or its not engaging the bevel gears down there deep in the bowles of the housing?? How does it feel if you try n turn that engage lever???
Even when the clutches are worn badly and even if the adjustments are wayyyyy yy out, she ought to turn some even though it may slip under a load.
Oil is your own choice, I run 15W 40 in older worn engines or 10W 30 in better engines. Many run straight weighgts like SAE 30 in summer and maybe 20W in winter.
John T
Greasy hands
03-19-2005 17:06:27
 Re: 620 pto not turning in reply to John T, 03-18-2005 05:47:21
Well actually it does turn except when under load. I will have to do some investigating. Thanks for all your help G.H.
cole in mo.
03-17-2005 23:31:08
It could be as simple as just putting it in gear before you start the tractor, to doing simple adjustment, to spending big bucks for a clutch pack rebuild. Get a manual before you start working on it, it showes and tells everything will need to know.
