Baker Multi valve Instruction
No Wheels
03-17-2005 17:43:47
I am looking for instructions on how to install a baker multi valve on a john deere Farm tractor. Help needed! Thanks
CMB
03-18-2005 07:07:35
 Re: Baker Multi valve Instruction in reply to No Wheels, 03-17-2005 17:43:47
Nothing to it, just remove the "Power Lift" or "Power Trol" valve body. Using two new gaskets,(you may want to put some type of gasket sealer here) "sandwich" the Multi-Valve between the original valve body & the rockshaft housing. Use the bolt extensions that should be with the Multi-Valve. If you didn't get the extenders with your valve you'll have to buy longer bolts.
