420 crank case pressure
T Johnson
03-17-2005 15:42:31
I have a 1957 420 W that was leaking oil from the main bearing seals. I replaced the seals and it still leaks. I have found that I have a pressure build up in the crankcase that may be blowing the oil out the seals. A compression check tells me I have about 110 pounds on each cylindar. As far as I can tell, the head is clear around the push rods where I assume any crankcase pressure is released through the valve cover vent. Any help would be appreciated.
jCarroll
03-23-2005 10:16:01
 Re: 420 crank case pressure in reply to T Johnson, 03-17-2005 15:42:31
This is not a gee-whiz answer, But if it were mine, I would remove the valve cover and run it awhile to SEE that the valve train oil is freely returning to the crankcase, and blow-by is coming up.
If so, check the breather pipe on the valve cover -it has a baffle that almost closes the pipe, and something might have plugged the pipe there
T Johnson
03-23-2005 12:10:32
 Re: 420 crank case pressure in reply to jCarroll, 03-23-2005 10:16:01
Thanks for your response, I have done all of what you suggested. The breather pipe is free, the oil drains from the lifter area and I get air up past the push rods. My 110 lbs of compression may not be close enough to the 135 the book suggests and maybe I am getting too much blow by for the ventalation system. All I know is I replaced the crankshaft oil seals and they both leak..... . :>(
